Anyone know where I can get them from? Can't seem to find them anywhere.
Which one do you need- I may be able to help 🙂
There's more than one? The one to bleed old Saints BR-M800
Aye that yellow thing!
Since M800 and M585 (LX) share the same pads the bleed block specified for M585s should do eh?
That looks like the Saint 810 spacer, the 800s use the same spacer as XT, LX etc brakes so you need one with the pad retention bolt hole at one end.
Ask you're LBS, they may well have a stock of them in their workshop
Do'h- matthew h is right. 2 secs, should have one in the garage you can have for nothing- fire me an email 🙂
just fold up some cardboard and shove it in!
Swisstony, I tried that using a bunch of train tickets - it just didn't work 😐
I use a couple of big (10mm, i think) allen keys.
Can I have the m810 spacer rockthreegozy? Can't for the life of
me find one ont interweb
I find them too thick to get my preferred lever throw.
I've always just filled Shimano brakes from the bleed screw up using a syringe, top caps off and catch the overspilled fluid with some blue roll. then pulled the brakes on a few times.
