Funny 'L' shaped block with 15 small holes in it and one bigger one. About an inch long and half an inch wide.
piston spacer, when you bleed the brakes, take the pads out and put it in...
for bleeding, put it between the pistons.
Has it got a half-moon cut out of it? If so, it does 2 things- one is that it can be a piston spacer, if you take the pads out. The other is that if you take 2 of em they act as a hose clamp for when you're fitting the insert thing into the hose.
They L shaped yellow ones are spacers. They're to stop the pistons popping out if you accidently apply the levers when there's no pads/rotor in place. There may be a thin red one to approximate a rotor when there are pads fitted but the rotor isn't in place.
The other yellow block may be a two part one for cutting hose.
Cheers gents - will teach me to RTFM!
