So, I'm changing from my HT to a FS soon, but using all the same components, so essentially swapping frames. The new bike is 140mm travel, and my Yari's are currently 130mm.
They're 27.5 Plus, Boost spec, and I can't work out what air shaft I need to get! Do I get the 140mm 27.5 or 140mm 29 air shaft? Since they're basically 29" wheel fitment...
The whole range is for sale here, and I just don't want to get it wrong!
https://www.bike-components.de/en/RockShox/Air-Shaft-Solo-Air-Pike-Lyrik-Yari-p51680/
Thanks
you either have 27.5 boost yari or a 29/27.5+ one, it will say on the back of the fork.
So there isnt really a 27.5+ fork specifically just a 29er one that is also 27.5+ compatible.
29/27.5 Boost then. So, a 29er 140mm air shaft?
Id say so yeah, as they are 29er forks. Not actually done it myself though as didnt have yari`s for very long...
I'll report back, I've ordered the 160mm 26" wheel travel air shaft from CRC, same part as on bike-components.de, but cheaper.
They are shared parts so it usualy says 29" 140/27.5"150/26" 160 etc on then anyway. Like when I fitted a bunch to peoples bikes making 150 bikes 160 in 27.5" they all flogged the shafts to their mates who had 26" pikes to make theirs 160 as well.
