XX1 42T replacement...
[Closed] XX1 42T replacements?
[#6872952]
Just found a broken tooth on the 42T sprocket of my XX1 cassette.. that'll be why it's started slipping then! 🙁
A bit of Google Fu throws up [url= http://www.aribike.it/pignone%20sram%20XX1%20html/pignone_cassetta_sramXX1.htm ]this[/url] from Ari as a potential replacement so I thought I'd share it.. anyone tried one, or come across any other alternatives?
[img] http://tinyurl.com/ks4kof7 [/img]
Posted : 18/02/2015 10:28 pm
You mean you don't fancy stumping up £200 for a replacement for a broken tooth?
Posted : 18/02/2015 10:30 pm
Thread hijack - does anyone know if the x1 42t can be replaced or is a whole new cassette needed?
Posted : 18/02/2015 10:42 pm
[quote=kudos100]You mean you don't fancy stumping up £200 for a replacement for a broken tooth?
<charades>Puts finger on nose and points at kudos100</charades>
[quote=matther01]Thread hijack - does anyone know if the x1 42t can be replaced or is a whole new cassette needed?
From BikeRadar: "The largest, 42t cog is constructed from aluminum and pinned in place in the same manner as on the higher-end cassettes."
So I guess you should also be able to use the replacement I linked to above..
Posted : 18/02/2015 11:00 pm
