XTR M985 cranks arm...
[Closed] XTR M985 cranks arms
[#4823562]
Is there any difference (except for the chainrings) between an XTR M985 double and triple chainset, i.e. are the cranks arms the same?
Thanks
Posted : 01/02/2013 1:17 pm
Top of my head there are some diffs,
26/38 (M980) have the same bolt circle diameter (BCD) as normal cranks.
and the xtr triple I believe,
where the bigger 28/40 + size have a diff BCD to other cranks.
Also the chain line is a little diff between them.
look on Shimano website in tech docs, (fitting instructions, info should be there.)
Apart form that the construction is the same as far as I know.
Posted : 01/02/2013 1:52 pm
Yep, 88mm BCD on the larger ring doubles, 64mm on the smaller ones, standard 64/104mm on the triples.
Different chainline, and the q-factor is narrower on the doubles - shorter axle I assume.
Posted : 01/02/2013 1:59 pm
 LeeW
It's a different shaped spider/arm njee, I was hoping to solve my chainring hitting the chainstay problems by swapping chainsets, to no avail.
Using 1.5mm spacer at the moment, I wish I could get an XTR chainset with a 5mm longer axle. Hoping the new E13 TRSr chainsets will help whne they're out in March.
Jeff Steber, if I ever meet you I'm going to make you eat my chainset.
Posted : 01/02/2013 2:08 pm
