Looking for a new chainset and fancy the XTR (last generation) and trying to work out the various options.
The M980 appears to be available in double and triple so...
Which would be the best for a single ring set-up and, if I'm removing the rings, will I need new caps like these:
[img]
[/img]
Steve
Triple is best, doubles either have a slightly quirky chainline, or a unique BCD, although neither is insurmountable.
You won't [i]need [/i]those caps, but you may think it looks better. Personally I don't - the Shimano ones look good, but the aftermarket ones look a bit crap IMO, as they're such a different colour to the spider.
I have M980 TRAIL double cranks on my 1 x 11 set up.
You have to make sure its the M980 and not the M985 though. Nick is absolutely right in the the M985 has a 96BCD but the M980 Trail double has 104BCD
I use mine with a 104BCD Wolf Tooth ring (without caps)
Get a double Trail (M980) version. Race double (M985) has a smaller BCD that limits thick/thin ring options.
Trail double has the spider caps included. You'd benefit from running 2mm spacers between the spider and ring though, as the double chainset runs a wider chainline than the triple.
88mm on the M985, but yes, point still stands 😉
Its the same as 96BCD, only different HAHA
The Shimano caps are really nice but they're stupidly expensive IIRC. I'm not sure I trust anything other than steel bolts for a singlespeed anyway!
So I'd be going for the M980 (not 985 which is smaller BCD) and triple is better chain line than double? If I got the triple, for aesthetics, I'd need caps of some sort, either Shimano or KCNC type.
The double would come with the caps I could use?
I could make a spacer to adjust the chainline, although my XT double runs fine with the single ring
Same chainline on XTR double as the XT double. 2mm spacer (Wheels Mfg do them) improves things. Cheaper than buying the caps too.
As I say....I use M980 double with a Wolf Tooth (or Absolute Black) ring. No spacers etc and it works perfectly.
I can use the caps with the Wolf Tooth but not the Absolute Black as they don't quite fit because of the cut outs in the A.B. one
http://www.ukxcnews.com/race-bike-focus-ktm-impsport-team-bike-garry-hurst/
Some pics of my set up here
Cool, thanks chaps.
^^ nice bike and interesting write up. Do you use GPS to 'navigate your cassette' 😀 How are the 'dependable M985 pedals' behaving - in my experience they can be depended on to be undependable in the staying in one piece stakes!
Piss take aside nice bike
