XTR M970 Crank, Sin...
[Closed] XTR M970 Crank, Single Front Ring options, which one will suit this crank.
[#2122762]
Ive been running single on my 29r for a while with a FSA crank am i right in thinking the XTR M970 has different spacing. If so any advice on a replacment ring would be great. I'm looking to run 34 or 35t.
Posted : 25/10/2010 12:24 pm
Nope, you can run what you want. If you change the granny you need some 2mm spacers, but BCD is standard 64/104.
Posted : 25/10/2010 12:27 pm
Spacing doesn't matter if its a Single ring. The BCD is 104 like most other 4 bolt cranks.
many thanks.... Renthal it is then..
Posted : 25/10/2010 12:33 pm
