XTR M970 Chainsets ...
[Closed] XTR M970 Chainsets - Alternative chain rings to Shimano?
[#1254876]
Anybody use alternative (that is non-Shimano) chainrings on an XTR M970 chainset?
I'd like to use Middleburn hard coat rings if possible
Any help appreciated
Ken
Posted : 24/01/2010 6:47 pm
I use TA Chinook on mine in a 2x9. You have to space the granny ring I think if you're using all 3, but it'll work.
Posted : 24/01/2010 6:49 pm
Stand by to get flamed! You'll get lots of comments about buying XTR but can't afford the parts. I've not put spare rings on my XTR yet but I don't think I'll drop the sort of money that Shimano want for a set of three. I've had some bad experiences with Middleburn rings on a different crankset so personally I'd be looking elsewhere. I see Poshbikes do TA rings and they have a set specifically for the 970 XTR. Not tried these but TA have been good rings in the past. They're what I'd try if/when I find myself in your shoes unless someone who has tried them says different.
HTH.
EDIT: - SISMIC TA rings are what you're looking for.
Posted : 24/01/2010 6:51 pm
Deore rings on mine.
Posted : 24/01/2010 6:55 pm
Bring on the flaming....I want to use a 36/22 rings and a bash guard so standard shimano rings ain't gonna cut it
Posted : 24/01/2010 7:00 pm
 LeeW
Will Race Face ones fit? I use them on my XT chainset and they're pretty good.
Posted : 24/01/2010 7:01 pm
Yeah the TA Sismic are the ones 'profiled' to fit the XTR spider, but they're not that much cheaper!
Middleburn will work.
Posted : 24/01/2010 7:07 pm
I've no intention of doing any flaming. I want a cheaper alternative as well but I've seen it happen a couple of times before when this question has cropped up.
I'm sure I've seen the set of three sismic rings for about £110~120. I thought ti was that for the XTR middle alone.
you could just use the proper xtr inner which isn't TOO expensive at £25, and any 36T middle, Race face etc. Save the need for additional spacers.
Posted : 24/01/2010 7:23 pm
There is little weight difference between deore and xtr granny and middle. You only need a few washers to space the granny out to make it work.
Posted : 24/01/2010 7:29 pm
Here's how I did it! As someone said at the time "bought a porsche and can't afford the tyres!"
[url= http://www.basquemtb.com/putting-cheaper-chainrings-on-xtr-cranks/ ]Cheap tyres for my porsche![/url]
Posted : 24/01/2010 10:02 pm
I've used a hardcoat middleburn. runs fine, no spacers or anything. same colour too. 🙂
Posted : 24/01/2010 10:58 pm
Used Middleburn slickshift / hardcoat as replacement on an 08 XT and they didn't shift as well or last as long as the Shimano rings. Shimano 09 XT I use on another bike are great and still going strong. Won't waste my money on Middleburn again.
Posted : 24/01/2010 11:30 pm
Have used Blackspire Pro XTR granny and middle ring to replace the Shimano ones and they were fine - just the outer ring that I'm not sure about!
Posted : 25/01/2010 12:55 am
SLX do a double and bash crank with those rings why not buy them. They are in stock at chain reaction
36t is £29.99 part no 1Kg 9805
22t is £9.99 part no 1KF 2200
Posted : 25/01/2010 9:57 am
deore steel all the way, last forever
middleburn in my experience can cause chainsuck because the middle ring is so thick.
Posted : 25/01/2010 10:04 am
You can fit whatever you want to the outer ring, it just won't match the profile of the spider, like this:
[img] http://newimages.fotopic.net/?iid=y69bqk&outx=800&quality=70 [/img]
Posted : 25/01/2010 10:24 am
