XTR M970 chainset t...
[Closed] XTR M970 chainset tool? TL-FC35?
[#8412574]
Has anyone got one I could borrow or even buy? Got to remove a left hand M970 crank and the tool is deffo required. Cheers 🙂
Posted : 22/03/2017 4:09 pm
where are you? i've got one in devon you could borrow.
Posted : 22/03/2017 4:15 pm
 Bolt
I have one near preston you can borrow?
Bolt
Posted : 22/03/2017 5:51 pm
Cheers guys very much appreciated!! I'm down in Sussex, should've said, sorry!
Might have a lead on one to buy...
Posted : 22/03/2017 6:39 pm
One here in Yorkshire. Can post if you promise to post back 😀
Posted : 22/03/2017 8:14 pm
 rob2
Do you 'really' need it? I've tapped mine off with a rubber hammer and they are fine if you are careful
Posted : 22/03/2017 8:39 pm
slug - Of course I would but will see if my lead on buying one comes good
Rob - tapping it off will put a bit of force on the soft splines as it's not pulling evenly, so it may work but not ideal.
Posted : 22/03/2017 11:58 pm
Used the tool on Rob Collivers M970 XTR cranks. They were so tight, that the tool broke, using a big lever in the hole.
Ended up with a Dremel and cutting them off. Fortunately they were destined for the bin.
Posted : 23/03/2017 8:51 am
