Its rounded - bike shop dont want to touch it - said they'd have to send it to their engineers and thus would cost a lot to sort ... Should I use a hacksaw to create a groove on bolt head to try loosening with a flat head screwdriver ?- Or should I hacksaw the bolt im two inbetween the clamp hinge - or should I drill it out ?
Dont really relish doing this but as Ive said the mechanics at LBS didn't seem to like the look of it ... If anyone's sorted this same problem I'd be greatful to know which method worked for them ... Wouldn't mind replacing with Ti as alloy seems super soft - Tried at LBS to order replacement XT steel version but according to LBS it has to be XTR as shorter...
I suspect if you move to Ti you'll just strip the thread the bolts go into...
compare cost of proper solution with a new lever (I assume it's a problem with lever clamp?) and decide if it's worth a bodge attempt from there?
Which bolt is it - the banjo that connects the brake line to the caliper?
Hammering a torx head in usually the first port of call, see if that bites and you can screw it out.
Google "Easy Out"
I got mine from screwfix but they don't sell the same ones anymore.
Removed the bolt from my oven element and also the bolt from an Time pedal cleat.
Next thread- "how do I get the snapped-off tip of an easy-out out of my brakes?"
Which bolts are alloy on any Shimano brakes?
njee20 - MemberWhich bolts are alloy on any Shimano brakes?
[pedant mode on] [b]All of them.[/b] [/pedant mode off]
Aluminium alloy then, how did I know that was coming 😉
1. Never snapped an easy out (maybe I'm overly gentle with them). Mine were £6 but I use the tap handle from a tap and die set to drive it.
2. Steel bolts can be shortened or can be bought in a variety of standard lengths if that's easier.
3. Go your good with a drill picking a drill bit of the same size as the bolt thread will allow you to very carefully drill the bolt head off. There will be a release of tension as the bolt head severs - be aware of it and stop drilling at this point.
Easy outs for me though
It's the xtr brake lever clamp bolt - M5 x 14.9 - there's quite a space between the clamp hinge so im assuming that if I squeeze a hacksaw in and cut then open the hinge I should be able to remove both parts of the bolt with needle nose pliers - I'll be well f##ked off if it goes tits up !
May be the bike shop didn't want to touch it cos it's just not economical for them - you're going to be sawing very carefully, taking your time - it'll take a while.
My thoughts would be to bang a torx bit into the rounded hole first and see if it'll grip it. Failing that drill the head off the clamp bolt, then hinge the clamp back and remove the threaded part of the bolt with pliers.
Feel a bit more comfortable going for hacksaw method than drilling out the bolt - it was mentioned that ti bolt replacement a bad idea - because it could potentially damage brake lever thread - is this because the xtr lever is magnesium? - is it safe to say that these levers have a standard thread pitch - compatible with with after market bolts? If the magnesium thread is weak maybe stick with the replacement xtr bolts ...
It was mostly that if you're tightening alloy bolts enough to damage it then all that well happen with ti is that you will tighten it enough to damage something else.
975 xtr? Jesus the bolts are made of cheese. And good luck finding a replacement, they use a very tight thread, and I couldn't find one that would fit.
Well it turns out that an aluminium brand x bottle cage holder bolt seems to be working just fine on the other lever and I will use the same on the chewed up side if I manage to get it off - does anyone know if the little clamp hinge should release if I cut the bolt between the clamp - ive already tried needle nose pliers between the gap between the hinge and can get no movement - Please understand I put absolutely zero excess torque on this bolt it just seized out of know where - I'm blaming the loctite!
I wouldn't cut it out, you may end up with a struggle to get the bottom threads out. Stick some penetrating oil over the bolt, bang a torx into it first, then if that fails cut a slot, then if that fails - big eazy-out. Then when that fails, get the drill out.
Then the big hammer.
Wouldn't it be easier to use a Dremel instead of a hacksaw?
Where are you? If local I'll have a look at it.
Boris
I hope you're joking?! On a clamp fastening? If so, I blame who ever thought that would be a good idea.
Fine mini hacksaw as close to the bolt head in the gap of the clamp band as you can and once the bolt is cut through, open the clamp and if it's got loctite on the threads, you'll be needing to find some Mole-Grips with good jaws to try and clamp the stump of bolt left.
Loctite? Heat and cold?
Bars off bike and in the freezer perhaps? Then a hair dryer?
If you drill the head off like I and others suggested then you should be able to remove the lever and hopefully have enough threaded section to get a decent grip on to unscrew. I wouldn't use a hacksaw as there will be very little to grip and you risk damaging your bars or lever.
My only worry about drilling the bolt head off is that when I did this to a seized chainring bolt - I still had to use a rubber mallet to get the chainring to break free - with the brake lever if it doesn't free up immediately after bolt head is drilled off then I'll still be left with hinge clamp stuck on the bars - Im thinking in order to do a sufficiently thorough drill job I'm going to be dangerously close to the hinge clamp's thread ....
You only need to remove the head of the bolt and some of the threaded section thats inserted into this bit of the clamp that isn't threaded, to enable you to get the clamp past the bit thats left, not drill the whole thing out.
So start with something like a 3mm drill bit to this depth, you can use some tape around the bit as a depth marker. Then do the same with incrementally bigger bits, i.e. 3.5, 4, 4.5 and finally, 5mm, 5.5mm may well be needed to separate the head from the threaded section. You may find you don't need to go in 0.5mm steps, so see how you go.
Once you've done this, you should be able to place a lever like a flat blade screwdriver between the clamp surfaces and gently prise them apart and over the stub remaining.
You'll obviously find it easier to work on if you rotate the bars, so that the bolt head is pointing up.
But do consider easy outs - I've used the successfully on many occasions over the last 20 or so years.
With those type of soft alu bolts I usually have great success with the easy option of just grabbing by cutting into the side of the head with a nice sharp/strong pair of side cutters.
So the saga continues !
Really wanted this sorted asap - and took the bike to the other LBS in town - the guys in there were super helpful and went for the hacksaw method and sorted it in no time - However as soon as I took bike out of the shop I realised my other lever was way out - as if the reach adjust had been opened all the way out - very strange I thought... So I took the bike back inside and showed them what had happened explaining that it was nothing like that when I bought the bike in for repair - Turns out the piston inside the lever was broken and according to mechanic there are no spare parts available for XTR race brake lever .. They were very apologetic and have agreed to sort it but they have to pay for the new lever which isn't cheap ..
Wait...what? They Removed the bolt from one lever, and managed to knacker the other lever in the process?
Yes that is exactly what happened - weekend ride cancelled ....
Total bummer.
is this a good time to mention I hate Shimano brakes, and think they are shoddy unrepairable garbage?
No?
Ok!
The brakes have been excellent - other than the soft fastening bolts on the levers - I was under the Impression that Shimano brakes are generally held in high regard ...
XTR Race brakes have steel bolts in the levers...
The bolts in my xtr brakes are soft - not the first person to state this ... I will be replacing with Ti when I.get bike back - cant believe how much hassle this has been !
With all due respect, they saw you coming. Those brakes are under warranty, so if it has just failed, then take that option. If the shop broke it, they should be fixing it. Why you're paying for it I have no clue...
With all due respect - it's quite clear I'm not paying...
Doh, I do apologise, I can't read.
They will be softer, that's my point. You need a decent steel bolt, and not to be a hamfisted oaf.
Alternately get an Allen key that fits properly instead of listening to this clueless idiot's re spout of something he's read on the internet.
It surprises me how often these stories appear regarding rounded bolts and seized bolts.
Decent allen keys,a torque wrench and some anti seize(copperslip)is all I generally use and never have a problem(probably just tempted fate there though).
Errr... Why am I a clueless idiot?
Sorry to be blunt, but how the hell do you damage the head on a steel lever bolt? They are hardly made of cheese as some claim and only need 1.5-2 Nm torque to hold the lever firm. I've never used anti-seize on my 985 lever bolts, just a sensible torque and never had a problem. You'd really need to crank them up tight to have damaged the head or not be able to get them out.
Rather than buy Ti replacements buy alu bolts, then you'll get a good feel for how to attach a lever firmly but be delicate with lever bolts. Ok, so that isn't a sensible suggestion but over torquing alu bolts does give a good lesson in how not to over abuse steel or Ti bolts.
The bolts have been replaced with M5 x16 aluminium bottle cage bolts - only 3/4 of a turn past finger tight - adequate clamping capacity .. The allen heads are much deeper no chance of rounding out - I think part of the problem with the original xtr bolts was also that they were very flush... Hope I get bike back early next weelk .... I still want the ti though - will use bottle cage again they are easy to oick up and look sweet - Blue ones!
What you have now replaced with alu, or you had done before? If the latter how did you round them? 😕
Green bolts are bestest!
I've replaced the original alu with deeper headed alu - and want to 'upgrade' to Ti ...
