xt single ring cran...
[Closed] xt single ring crankset
 MSP
[#7368655]
Just bought one this weekend, without a chainring, but on closer inspection it also has the fixings for a smaller inner chainring. Is this the wrong one on the box or is that the way they are.
Posted : 04/10/2015 5:07 pm
I also just bought one and found the same thing. I was wondering whether I'd been sent the wrong one. So there being two of us makes it (marginally) more likely they're all like that. Mine came from CRC.
Posted : 04/10/2015 5:31 pm
It's the same crankset for the twin and single ring setup. Don't panic
Posted : 04/10/2015 6:01 pm
 MSP
That's a bit shit if its right, that would put the chainline out.
Posted : 04/10/2015 6:04 pm
According to the shimano site there are 3 models, 3 different chain lines..
Deore XT M8000 1x11 Crankset
Deore XT M8000 2x11 Crankset
Deore XT M8000 3x11 Crankset
Model Number FC-M8000-1 FC-M8000-2 FC-M8000-3
Crank Construction HOLLOWTECH II Technology
Cassette Compatibility 11 11 11
Chain Compatibility
4-Arm Chainrings x x x
Chainring Sizes 34, 32, 30T (SM-CRM80), 38-28T, 36-26T, 34-24TT, 40-30-22T
Bolt Circle Diameter P.C.D. 96mm P.C.D. 96/64mm P.C.D. 96/64mm
Chain Line 50.4mm 48.8mm 50mm
Posted : 04/10/2015 6:49 pm
Just read a thread over on mtbr about the same issue, strange that the model number on the crank is just FC-M8000 no 1,2 or 3.
So god knows how shimano quote 3 different chain lines??
Posted : 04/10/2015 6:59 pm
When I get the mech on the bike and wired up, I may be able to tell you if I have the right one or not.....
Posted : 04/10/2015 7:11 pm
FWIW CRC gives 50mm and 53mm chain line options. Might this be the difference between those intended for 1x vs 2x?
I went for 50mm but not fitted yet.
Posted : 04/10/2015 7:45 pm
Be careful not to buy the B spec crankset too. B = Boost, designed for the wider chai line Boost 148 rear ends require. I think that's the 53mm chain,one model mentioned above.
Posted : 04/10/2015 7:54 pm
 MSP
Still not sure I have the correct one, it isn't the boost/53, but could be a double.
Posted : 05/10/2015 9:19 am
I have the m8000 'single' crankset from evans, mine has tabs for a granny ring too. I'm using it with a one up components narrow-wide ring, with their included 1mm spaces it puts the chainline from 50 to 49mm, the chainline is great for 1x10 with a standard 11-36 cassette.
Posted : 05/10/2015 9:31 am
 Rich
The double cranks use the same spider as the 1x cranks, so you could switch between double and single setups with the same crank sets
Quote from [url= http://dirtragmag.com/first-look-shimanos-new-deore-xt-m8000-group/ ]here.[/url]
Posted : 05/10/2015 9:35 am
delete
Posted : 05/10/2015 9:38 am
