XT Shadow Rear Dera...
[Closed] XT Shadow Rear Derailleur for Orange 5 - Should I go for Long or Medium cage?
[#640830]
Or does it make any difference? Thanks EV
Posted : 17/06/2009 2:27 pm
how many rings at the front? if only 2, then go for medium cage - if 3, then go long cage
Posted : 17/06/2009 2:33 pm
3, OK long it is then!
Thanks Mr.C
Posted : 17/06/2009 2:43 pm
no probs!
Posted : 17/06/2009 2:47 pm
Been running short cage on my 5 for 2 years with 3 rings up front and no probs
Posted : 17/06/2009 3:20 pm
The short cage shadow is nearly as long as the long cage non-shadow if that makes any sense. I use the short cage with a 3 ring and 11-32 setup and it's fine.
Posted : 17/06/2009 4:01 pm
short cage not much shorter, bit stronger, bit more out of the way, should be a bit quicker/sharper (but never noticed this), short will be OK and if you dont use big to big and small to small cogs -best not to as just too much chain line twist- go for a short. or what ever is the cheapest!
Posted : 17/06/2009 4:05 pm
Medium shadow is disappointingly long, much longer than a medium non-shadow. Why? Otherwise it's ace and I reckon easily long enough for a 3 ring setup. Look at a picture of a bike with the long cage on it, it nearly touches the ground FFS!
Posted : 17/06/2009 4:23 pm
Not XT but I use an X9 medium cage with three rings with no issues...
Posted : 17/06/2009 4:31 pm
I run XTR meduim, XT medium on all 3 ring setups.. granted I'm running a 42T cassette.
Posted : 17/06/2009 5:02 pm
Fitted a medium XT Shadow to my Five llast week (3 ring front) no issues at all.
Posted : 17/06/2009 7:14 pm
make sure that the XT shadow is the newer design without the tab or you'll wreck it. See the differences [url= http://www.rapiddescentscotland.co.uk/index.php?module=pagemaster&PAGE_user_op=view_page&PAGE_id=17 ]on my website[/url]. I ground mine against the cassette because the tab rides too close to the top sprocket on the cassette.
Posted : 17/06/2009 10:23 pm
