xt rear cassette
[Closed] xt rear cassette
[#4856111]
Over the past couple of months ive noticed when im pedeling on the last 3 rings it jumps not from ring to ring. Ive replaced my rear mech for a new one but still the same could it be ive worn them out
Posted : 10/02/2013 12:42 pm
I'd imagine so mate - that and your chain
How is the indexing of the gear?
Posted : 10/02/2013 1:22 pm
Chain is pretty new shifting is ok
Posted : 10/02/2013 1:25 pm
If i pop a pic on can u have a gander
Posted : 10/02/2013 1:26 pm
[img] http://www.flickr.com/photos/90541258@N02/8461723216/in/photostream [/img]
This is the casette
Posted : 10/02/2013 2:57 pm
Your photo doesn't work and you can't really tell through images
A new chain on a old cassette will always jump, unless it was swapped very early
The latest mud fest has played havoc with my drive trains - I needed a new chain ring on my 2x10 STX set up in less than 500 miles
Not a happy bunny
Posted : 10/02/2013 3:25 pm
Ah stuff it ill invest in a new one any thoughts should i get another xt or less or maybe move to sram
Posted : 10/02/2013 4:06 pm
I went with a used XTR for £15 and 2 new small cogs, lightweight and smooth shifting. the Big rings on XTR are unlikely to be the reason for the person selling the XTR 🙂 Plus you can buys individual cogs when required on XTR 🙂
Posted : 10/02/2013 4:09 pm
Sticky cable
twisted frame
bent chain
stiff link
knacked mech
sticky shifter
bent teeth
bad indexing
and probably a few more things it could be. This time of year i would go for the last length of cable being cacked up. replace that bit, or a new cable set might work. cheaper than replacing chains cassette.
cassette looks ok tbh
Posted : 10/02/2013 4:11 pm
All new cable brand new rear mech only 6 month old pc991 chain
Posted : 10/02/2013 4:15 pm
you could have a sticky cable from new, but you seem to think thats ok so good luck
Posted : 10/02/2013 4:19 pm
Silly thing it runs fine on the stand but when on the road and a bit of resistance there she goes
Posted : 10/02/2013 4:27 pm
Worn cassette
Posted : 10/02/2013 4:37 pm
Borrow a cassette and confirm if possible would be my preferred route
Posted : 10/02/2013 4:45 pm
Sorry to butt in,but where did you get the small XTR sprockets from?
Rang Madison and they told me they are not bringing in XTR,XT or SLX sprockets.When there buggered new cassette! 🙁
Thanx,
Max
Posted : 10/02/2013 6:17 pm
Thanx,
Max
IIRC Rose Bikes did them but the site won't load on my phone so can't confirm.
Posted : 10/02/2013 6:30 pm
I went ebay, but google bring up this...note its 9 speed
http://www.bicyclehero.com/gb/catalogsearch/result/?q=cs-m970
Posted : 10/02/2013 6:49 pm
10 speed here
http://www.bicyclehero.com/gb/catalogsearch/result/?q=cs-m980
Posted : 10/02/2013 6:50 pm
Rose bikes still have 10 speed...
http://www.rosebikes.co.uk/search/find/?q=m980
Posted : 10/02/2013 7:00 pm
Cassette looks worn. Compare the large sprocket with the smaller sprocket profiles.
Posted : 10/02/2013 7:11 pm
Good call!
Thanx,
Max
Posted : 10/02/2013 9:46 pm
