XT pads keep glazin...
[Closed] XT pads keep glazing...
[#576460]
i've been having some bother with a set of xt disc brakes on my i-Drive. The pads seem to keep glazing over, leaving very little friction between the pads and rotor. So far i've tried fibrax, ebc and will now try superstar pads, all of the sintered variety. I've tried filing them, sanding them, baking them, and cleaning the rotors with iso alcohol. These all work for about one ride, before the glazing returns. Has anyone else had similar experiences? Would i be better off going for organic pads?
Posted : 24/05/2009 6:14 pm
are these the old 4 pot xt's??
Posted : 24/05/2009 6:19 pm
Have you actualy bedded them in though? Ride a short sprint (50m) flat out and brake hard without locking the wheel, repeat several times.
Probably would, sintered pads create a lot more heat(which is the cause of glazing)than organics, great in the wet, not so clever in the dry. Another thing that may cause it is dragging of the brakes on descents rather than short hard applications which don't allow the heat to build up so much.
Posted : 24/05/2009 6:20 pm
i know it sounds crazy but a light sanding of the rotor surface may help.
Posted : 24/05/2009 6:22 pm
they're not the 4-pot ones. I used sintered pads on those without any problems. I do always bed them in with several sprints followed by sharp braking to a stop. I probably am guilty of dragging the brakes rather than using them harder and less frequently. I'll look into organics then. What do others use?
Posted : 24/05/2009 6:27 pm
i always had this problem with my 4 pots and sanding the rotor helped.
Posted : 24/05/2009 6:34 pm
thanks 111 - I'll give that a shot while I await the organic pads. Am I imagining things or did I read somewhere about semi-sintered pads, supposedly offering the best of both worlds?
Posted : 24/05/2009 8:33 pm
How big a rotor are you using?
Posted : 24/05/2009 8:34 pm
200 on the front, 160 on the back. Both front and back have exactly the same issue. On thinking about it, the problems would seem to coincide with me gaining a bit of weight (13st -> just under 15st), so that would backup the too-much-heat theory. Maybe?
Posted : 24/05/2009 8:36 pm
I get this on both bikes with XT sintered pads. I've used Shimano, Goodridge and Carbon Lorraine pads, all the same result. HT tows the kids trailer on tarmac - glazed pads (weight of me+trailer+kids+bike=170kg), and the FS with 200mm rotors, with just me, glazed. I've sanded both pad and rotor, degreased, deoiled, brakecleaner, alcohol, one ride later I cant lock a wheel. Jump on the road bike and I'm impressed by the power of the brakes.
It's got me beat.
Posted : 24/05/2009 10:18 pm
Try a smaller rotor. I'd say "not enough" heat actually. A smaller rotor will get hotter and won't result in glazed pads.
Posted : 24/05/2009 10:20 pm
Bin the pads off and go for the resin compound, miles better performance than sintered in all conditions IMO. Yes you'll be replacing them more frequently but you'll also have brakes that work!!
Posted : 24/05/2009 10:40 pm
yeah my sintereds on 160s havnt worked since i boiled them coming down ben nevis , but the levers still feel very positive negating any possible leaks (given ive searched high and low)
i may go back to resins ... infact i have a set of supershit resins here im willing to sacrafice in the name of science .... ive not dared put them near the bike for any other reason !
Posted : 24/05/2009 10:54 pm
Druidh is right - glazed pads happen when the brakes are used a lot at below optimum temperatures / gently Brake in harder bursts or get smaller rotors
Posted : 24/05/2009 11:18 pm
thanks all. Some really good suggestions there. I'll try a smaller rotor first then resort to resin pads. Trail_rat, let me know how you get on!
Posted : 25/05/2009 11:31 am
 a11y
I get this sort of thing too - XT M765s, the 2-piston, silver ones. I'm using the original pads, 203mm/160mm rotors and have the same problems. Feel great at the levers but sod-all stopping power. They certainly got better towards the end of my ride on Saturday (after 20km) and also perk up if you dowse them in water, until the water dries off.
What type of pads come in them as standard?
Posted : 25/05/2009 12:49 pm
 a11y
Posted : 25/05/2009 12:50 pm
Where are you riding that you think you need 203mm rotors?
Posted : 25/05/2009 1:21 pm
 a11y
I couldn't get a suitable adaptor for the fork to allow a 180mm rotor! It was 203 or nothing, and certainly helps slow my bulk down...
Are standard Shimano-supplied pads resin or sintered?
Posted : 25/05/2009 1:28 pm
a11y - Member
I couldn't get a suitable adaptor for the fork to allow a 180mm rotor! It was 203 or nothing, and [b]certainly helps slow my bulk down[/b]...
a11y - Member
I get this sort of thing too - XT M765s, the 2-piston, silver ones. I'm using the original pads, 203mm/160mm rotors and have the same problems. Feel great at the levers but [b]sod-all stopping power[/b].
This doesn't strike you as a bit inconsistent?
Posted : 25/05/2009 1:30 pm
 a11y
Well they worked fine for the first few months, that's what I meant to say.
Posted : 25/05/2009 1:31 pm
if you are getting a sort of uuuurrrrrrcccchhhhh noise then its pad contamination, probably from rather liberal spraying of GT-85 or WD-40 in the same room as the rotors. Most of my customers who have this also have OCD clean bikes. Remember that GT-85 etc sprayed in a confined place will somehow, defying the laws of physics, find its way onto the rotors.
Posted : 25/05/2009 3:57 pm
My riding is around Scotland - mainly the Stanes or local trails (Falkirk/Stirling), but trying to venture out into nature more. The 200mm rotor came stock on my bike - this was before Shimano came out with the 180's.
Rapiddescent - I think I know that uuuuuurrrrrcccchhhhh noise you mean, and yes my bikes are normally kept quite clean and well lubed, although I do tend to avoid spraying it unless I'm outside. One thing I had thought of was that when venturing further afield, my bikes are carried on a tow-bar mounted rack, and I was wondering if the emmisions from the exhaust were maybe contaminating the rotors, and then the pads. Is this likely/possible (I've no idea if burnt diesel is as slippy as non-burnt diesel). Do other people cover their discs when carrying their bikes on such carriers?
Posted : 25/05/2009 4:13 pm
actually, hadn't thought of that because the rotors would definitely pick up oils from the road and the back of the car. I don't really travel with the bike in/on a car anymore because of the sheer number of trails local to Stirling and so I've not had this on my own bikes. Also I don't really clean them well enough!!
If you need to burn off the oils, meet up with the stirling bike club for a fast ride down Dumyat (our local hill) and that will have the rotors glowing in no time at all !!!
Posted : 25/05/2009 4:39 pm
