XT M8000 again
[Closed] XT M8000 again
[#7337666]
Just in case anyone wondered, an XT medium cage 11 speed rear mech does work on a 10 speed cassette (11-14 with T-Rex) and 10 speed XT shifter.
Rather well, I might add.
Posted : 17/09/2015 11:25 pm
Ooh, that's interesting to know!
Posted : 18/09/2015 7:47 am
that's a rather close ratio cassette you're using pal
assume you meant 11-40 or 11-42?
Posted : 18/09/2015 8:11 am
Ha - indeed - SLX 11-36 with a T-Rex on and the relevant smaller cog removed.
Posted : 18/09/2015 8:31 am
40 or 42? just interested 'cos it'd be handy if the mech design did away with the need for faffy replacement cages and stuff like that when using a 42t expander
Posted : 18/09/2015 8:52 am
T-Rex is 40t, but as there is an 11 speed 11-42 XT cassette, I see no reason why it wouldn't work on 10 speed 11-42 as well.
For comparison, I was running a Zee FR mech and I thought that was good, but the XT GS mech is loads better. Upper jockey wheel looks like it's placed very similarly to a 10 speed mech with a Rad/Radr cage.
Next on the list is the proper 11 speed cassette and shifter - will try other conbinateions when I get them.
Another thought - did I read that an 11 speed SRAM mech will work with an 11 speed Shimano shifter (or Shimano mech/SRAM shifter)? If so, 11 speed Shimano mech may work with SRAM shifter, if youre are sufficiently deviant enough to use SRAM.
Posted : 18/09/2015 10:43 am
I'd interested to hear about interoperability of sram & shimano 11spd.
New bike comes with X01 kit but if there's an option to fit an XT mech when the inevitable mech-mangling event happens, then that would be good.
Posted : 18/09/2015 10:52 am
Another thought - did I read that an 11 speed SRAM mech will work with an 11 speed Shimano shifter (or Shimano mech/SRAM shifter)? If so, 11 speed Shimano mech may work with SRAM shifter, if you're are sufficiently deviant enough to use SRAM.
[url= http://blog.artscyclery.com/science-behind-the-magic/science-behind-the-magic-drivetrain-compatibility/ ]Some info on pull ratios etc here[/url]
From what I can glean from that about 11 speed cable pull(shifter) and pull ratios (mech) and a bit of calculation...
------------------------------------------ Pull x Ratio = cog pitch
All Shimano: ----------------------- 3.6mm x 1.10 = 3.96mm
All SRAM: -------------------------- 3.5mm x 1.12 = 3.92mm
SRAM shifter/Shim mech ---- 3.5mm x 1.10 = 3.85mm
Shim shifter/SRAM mech ---- 3.6mm x 1.12 = 4.03mm
For me, that's too little variance to rely purely on the theory and suggests that all the combinations would be worth trying out.
Interestingly, the cog pitch on both Shimano & SRAM 11 spd cassettes is allegedly 3.9mm
Posted : 18/09/2015 1:02 pm
Are you using a 10 speed chain in this setup teeth grinder?
Posted : 19/09/2015 7:45 am
I am. All 10 speed except the XT mech at the moment.
Posted : 19/09/2015 9:19 am
Interesting this teethgrinder and you say it works well nice and crsip shifting ?
Posted : 19/09/2015 9:34 am
Better than the Zee, though the jockey wheels ended up more like wobbly ninja throwing stars.
Posted : 19/09/2015 9:36 am
Good work teethgrinder.
Makes me wonder what shimano are up to though, it seemed like they had started a policy of planned obsolescence with dynasys and roadie 11 speed, now they're rolling out "backwards compatible" parts again?
Posted : 19/09/2015 9:44 am
Thanks for the information. I recently got a 40t expander for my old 10 speed XT set up and was thinking about a radr cage... but now I'm thinking that a XT M8000 would be a better investment to improve the shift quality which definitely degraded with the b tension close to the end stop!
Posted : 19/09/2015 10:40 am
More news - Just fitted the 11-42 and bar mount shifter M8000 parts. Lovely kit, and a shame the cover disc isn't available yet. Gorilla tape FTW.
What I didn't do was use an 11 speed chain - kept the 10 speed HG54 and added a link or 2 and it's fine.
No need to buy 25 quid chains 🙂
Posted : 19/09/2015 1:58 pm
10 speed cassette doesn't work with 11 speed shifters and mech - hardly a shock, I know!
High gears/smaller cogs work OK, but when the chain gets to the 40t T-rex it won't take without a further click.
Posted : 20/09/2015 7:36 pm
A friend came over with a bust XTR 11 thumb lever at the UKGE this weekend, wondering if I could fix him up. All I had spare was a GX 11 shifter, so we stuck that on instead expecting to at least get a handful of ok gears, but instead we got them all. Arguably the shifting was actually improved. I saw him later and he'd snapped his brake lever off too. Good and strong those carbon XTR parts.
We've also done some XD cassettes with XT drive, as expected all good.
Posted : 21/09/2015 7:26 am
Glad to hear it. I'm thinking of running xt11 with a sram cassette just so it doesn't gouge the freehub body. Slightly better range would be nice as well.
Posted : 21/09/2015 7:38 am
Just to say I have now fitted a XT M8000 RD for not much more than the cost of RADr thanks to that well known Northern Ireland retailer. Shift quality now absolutely luverly on my 11-40 ten speed setup after a fairly demanding weekends riding. The only thing that causes me any puzzlement is the B adjust is at minimum and the top derailleur cog is still around 10mm from the 40t, can't get it down to the recommended 5-6mm, but no ill effects to report.
Posted : 28/09/2015 4:53 pm
according to the link ecky-thump posted, the M8000 mech has a pull ratio of 1.1, whereas a 10spd mech is 1.2, so the M8000 will undershift slightly.
this may not be a bad thing as my full 11spd setup actually overshifts a bit.
Posted : 28/09/2015 7:50 pm
