Does anyone know if the XT Shadow Plus+ rear mech is 9 speed compatable?
I'm running a 10 speed chainset OK on 9 speed chain & cassette.
Not with Shimano. But, you can tweak it fairly easily to work on SRAM X-series 9-speed. Just needs a little spacer on the mech which effectively lengthens the arm, to match up the pull ratios.
Not completely true. There is a mod detailed on pink bike or somewhere showing how adding a washer of a certain size meant you could have 9 speed and shimano shadow plus.
And for a neater solution.[url= http://www.ridemonkey.com/forums/f19/anyone-using-9-speed-sram-shifter-shimano-10-speed-derailleur-257028/index3/ ]http://www.ridemonkey.com/forums/f19/anyone-using-9-speed-sram-shifter-shimano-10-speed-derailleur-257028/index3/[/url]
That's exactly what I was talking about. But it doesn't work with Shimano shifters, only with SRAM.
That's bloody ace. I ducking hate my x7 Mech. 9sp and Clutch here I come. I've got a few washers and some old hope brake shims I can use to bodge a spacer.
Cheers chaps.
