Need to replace the front hose on my M775's and can't seem to find a hose that lists it.
Looked on the hose and there is no marking.
CRC lists two the BH63 which fits older XT brakes and BH90 for XTR's.
can anyone confirm if either will work. I seem to recall that the newer brakes use hose with a narrower internal bore, would this cause issues if I got the BH90?
Cheers.
try superstar as they have a fitment guide
When i replaced mine, i got some from dun dun duuuuuuun Superstar. Work fine, and didn't notice any difference from the originals.
Neither of those.
you want a straight end to straight end IIRC. No banjo bolt of the caliper.
This I'll do for a front.
That'll work. Just need the olive/barb and nut then.
Curious though, if the new BH90 hose is the same external diameter it should fit the older brakes as well, if used with the right barb for the narrower internal diameter, will it improve the braking in any way? Shimano obviously changed for a reason, can the older brakes benefit from it?
I needed to replace a hose on my bargain CRC M486 brakes this week (BH59 - barb and olive at both side). Could not find a BH59 for love or money long enough, but found Merlin have a better range of hoses. Opted for the Deore M596 BH90 (Barb and olive at both sides) for £11 including fittings.
