xt m775 brake issue
[Closed] xt m775 brake issue
[#4389559]
got a set me xt m775 brakes and the last 2 rides i've been on they have lost pressure and had to pull lever right to handle bars. Replaced pads and re bled both and today it happenede again, about 20 miles in it did the same. When i bled them i leave overnight with tops off to get air out. Do you think there is a leak or maybe air in system as its a bit weird for both to go. Anyone else know how to bleed properly or had same problem? Any help, thanks. 🙂
Posted : 22/09/2012 8:26 pm
I had similar symptoms, it turned out to be the calliper piston seals.
Posted : 22/09/2012 11:49 pm
If you are bleeding properly you don't need to leave the reservoir caps off. Do it from the bottom up and use the proper Shimano kit. It really does make it a dawdle.
Posted : 22/09/2012 11:55 pm
are the calipers serviceable?
Posted : 23/09/2012 6:59 am
should have bought Hope!!!
Posted : 23/09/2012 7:20 am
Normally by buying a new one with Shimano
Posted : 23/09/2012 7:27 am
Your callipers should get replaced under warranty as there was a manufacturing fault with some batches.
Posted : 23/09/2012 10:09 am
Anymore info on the manufacturing defect? I have a leaking caliper too.
Posted : 23/09/2012 11:25 am
 sbob
[url= http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Bleeding_SI/SI_0037A/SI_0037A_002_EN_v1_m56577569830648123.PDF ]Shimano does.[/url]
Posted : 23/09/2012 12:13 pm
+1 for the proper bleed kit, took about 5mins to do my xt 775 brakes
Posted : 23/09/2012 5:53 pm
