xt m770 gear set et...
[Closed] xt m770 gear set etc
[#3148031]
thinking about getting xt m770 cassette front and rear mech and shifters, are these a good upgrade from standard deore kit?
http://www.chainreactioncycles.com/Models.aspx?ModelID=20684
http://www.chainreactioncycles.com/Models.aspx?ModelID=20699
http://www.chainreactioncycles.com/Models.aspx?ModelID=20677
http://www.chainreactioncycles.com/Models.aspx?ModelID=20701
Posted : 14/09/2011 7:06 pm
that is a link to a wishlist - will only show up what you have in your own when logged in.
try merlin and the european sites (forget which, someone will be along shortly) when looking for groupsets.
Posted : 14/09/2011 7:09 pm
changed links
Posted : 14/09/2011 7:17 pm
What's wrong with your current Deore kit?
If it isn't broken, there isn't too much difference in functionality / feel to make a difference in the real world; for the cost it will take to change.
If you really wanted to change and get XT, get 10 speed, to justify it.
For the Euro sites, there's Rose, Actionsport and Bike24 amongst others
Posted : 14/09/2011 8:01 pm
Shifters first, they're definitely better even than SLX IMHO.
The rest? Replace when they wear out / break.
Posted : 14/09/2011 8:15 pm
My SLX 10spd is every bit as good as the 9spd M770 XT stuff it replaced, even when the XT stuff was new.
I'd not be buying new 9spd kit now. I'm sure I read Deore was going 1x10 next time around.
Posted : 14/09/2011 9:12 pm
aye tbh does anyone need more than Deore these days for general riding? It's been sneaking up in spec the last couple of years and i would have no problem saving a couple of hundred £ to put towards a better fork or lighter wheels by sticking with Deore than XT.
(but yes I understand that if you can afford it then why not. But still, Deore is not to be sniffed at)
Posted : 14/09/2011 9:31 pm
 Crag
Completely agree on the quality of deore kit.
I managed to bust an XT shifter and had a Deore kicking around in the potting shed. Shifting is every bit as good. Only downside is that the windows needed bastardising with a hacksaw to remove so I could get them in the right position.
I can't see me replacing until it breaks.
Posted : 14/09/2011 9:55 pm
cassette is wearing, fitted a new chain and now it skips now ana again, the crank set is new. as for the rear mech i wanted somthing with direct cable routing so i dont have to have the large loop going into it
Posted : 15/09/2011 7:34 am
Why not go 10 speed slx from rose bikes or xt if you can afford it, its so cheap from rose bikes for the new 2012 stuff
Posted : 15/09/2011 8:00 am
