XT caliper sticky p...
[Closed] XT caliper sticky piston
[#632522]
Ok, so before I spray some gt85 in there and rot a seal or something, can someone suggest a more sensible course of action?
Posted : 14/06/2009 8:14 pm
pads out pump brakes to reveal pistons (not too much) and then use a thin item such as a match to dab some mineral oil (shimano brake fluid) on to the sides of the sticky piston and then push it back in. Repeat a few times and clean caliper to ensure no oil is left to contaminate pads.
Also look back through earlier postings as this problem has been brought up quite a few times. In one of them some type of red grease was being recommended.
Posted : 14/06/2009 9:00 pm
Thanks Hustler, I'll give that a try.
Posted : 14/06/2009 9:34 pm
it was my thread and red rubber grease sorted it out no probs, use the same technique as above. easy peasy
Posted : 14/06/2009 10:27 pm
