XT 11 speed cranks ...
[Closed] XT 11 speed cranks and BB do they come with the 3 spacers
[#7664919]
Just about to install but no spacers i.e. 2 drive side 1 on the non drive.
They are the double set up but just using a single ring not sure if I should be using the spacers
Rich
Posted : 22/02/2016 8:47 pm
If you've got a massive shell you won't need them, they're a normal width axle AFAIK
Posted : 22/02/2016 8:49 pm
frame is a whyte 130 2014, just taken off the original GXP sram cranks
Posted : 22/02/2016 8:51 pm
Youll need spacers if its a screw thread one I believe, I don't recall Whyte doing a 75.5mm BB shell.
Posted : 22/02/2016 8:56 pm
just found the bloody things inside the plastic tool!!!!
Posted : 22/02/2016 9:09 pm
What spacers should be on for a 1x11 XT bb and cranks?
I've got one thick one on the drive side. Is that right?
Posted : 22/02/2016 9:11 pm
If you have a 73mm wide BB shell then yes, 68 runs 2 drive, 1 non drive.
Posted : 22/02/2016 9:12 pm
Ok great. I do think I'm going to switch to the non drive side to see if it helps the chain line.
Posted : 22/02/2016 9:14 pm
no spacers needed in the end struggled to get the preload cap on!!!
Posted : 22/02/2016 11:35 pm
Have you measured the BB shell? Is it a threaded one?
Posted : 23/02/2016 12:00 am
Threaded just been for a ride setup is perfect!
Posted : 23/02/2016 12:01 am
