XO shifter mount ch...
[Closed] XO shifter mount change? help needed.
 DJTC
[#6360053]
Hi just got myself a new canyon. XO shifter and Xo Trail brakes. the shifter is directly mounted to the brake. is there any way to change this as I want to change the brakes for my XTR trail brakes so would need a bar clamp for the shifter.
any help appreciated.
cheers
Posted : 23/07/2014 4:41 pm
Is this what you are looking for?
Posted : 23/07/2014 4:54 pm
 DJTC
potentially yes. so would the shifter screw strait into that?
Posted : 23/07/2014 6:25 pm
You should be able to pull the fixing bolt from the clamp that you have and remove the brake lever body.
You can then fit your XTR brakes and get riding, find the right bar clamps if you sell or fit the XO brakes to another bike.
Posted : 23/07/2014 8:32 pm
 DJTC
thanks for your help! could you tell me where you found that? cant see where to buy one.
Posted : 23/07/2014 9:42 pm
I think Tweeks would stock them, probably for earlier versions and I'm not sure about compatibility.
Posted : 23/07/2014 9:44 pm
 DJTC
ok. thanks for your help
Posted : 23/07/2014 10:30 pm
