Xo front mech repla...
[Closed] Xo front mech replacement
[#9786253]
Hi folks struggling to track down the correct direct mount s3 39 tooth bottom pull xo mech...will a shimano e2 do the same job? Cheers folks
Posted : 22/01/2018 12:01 pm
2x10 by the way
Posted : 22/01/2018 2:10 pm
I've switched between SLX and X0 FDs for 2x10 no problem. The 'shift ratio' is near identical for both make's of shifter.
Posted : 22/01/2018 4:58 pm
Any other SRAM S3 FD should be fine too. I’ve run XT E2 FDs in a SRAM 2x drivetrain for years without issue.
Posted : 22/01/2018 6:29 pm
A Shimano E fit isn't the same. I've got a spare SRAM one.. X9 maybe? I'll dig it out. I swapped to an X0 on my Banshee thinking I'd save weight.. Ended up as about 3g in end.. Do'h!
Edit.. Not reading other posts properly.. E2 isn't the same as E fit?
Posted : 22/01/2018 6:41 pm
E2 isn’t the same as S3 or E... it’s a two bolt ‘low Direct mount’. Apologies if I confused anyone thinking I’d said it was, I intended to mean that it was compatible with the system and by extension other Shimano 2x mechs would be, not that it would fit the OP’s bike...
Posted : 22/01/2018 7:40 pm
