Xfusion Roughcut da...
[Closed] Xfusion Roughcut damper
 RicB
[#7583826]
Does anyone know where I could buy a Roughcut damper aftermarket?
I have a set of Slants with the RL2 damper, which is good but I've had a few niggles with it. Plus the new Roughcut damper is getting rave reviews.
I'm still on 26" wheels so don't really fancy splashing out £500 on a brand new fork when the slant chassis is still fine.
Posted : 17/01/2016 11:54 am
Guess your first port of call would be to phone/email upgrade to see if they have them or even do it for 26inch fork versions! Then ask for your local dealer and go from there.
Posted : 17/01/2016 12:18 pm
 RicB
Thanks - trying that route but not having much joy. It's the same damper for all 34mm forks afaik
Posted : 17/01/2016 12:27 pm
 tish
Wouldn't mind trying this on my sweeps if it's possible
Posted : 17/01/2016 12:49 pm
We spoke to Upgrade last year about this and were told that Roughcut dampers (on their own) would likely follow in 2016. XF were keen to focus on complete fork production, understandably.
We're meeting with XF/Upgrade at Core show at the end of this month, this is on the list. Email if you'd like keeping in the loop - info@18bikes.co.uk
Posted : 17/01/2016 1:08 pm
 tish
Thanks Simon
Posted : 17/01/2016 1:42 pm
The damper is excellent but I would also recommend as highly the new seals and what I think is a stronger negative spring.
Posted : 17/01/2016 4:47 pm
I emailed X-Fusion about this a month ago, I was told the damper will be available as an aftermarket drop-in part in about 8 months.
Posted : 17/01/2016 9:50 pm
