XD driver creak
[Closed] XD driver creak
[#10815526]
I have once before tracked a bike creak down to the cassette and xd driver interface and after cleaning it and re-greasing it has returned after 1000 miles of use . Has anyone else experienced this as an issue and has anyone found a permanent way to fix it?
It's one of those creaks that can send you around the bike before you find it and a quiet bike would be bliss
Thanks in hopeful anticipation for your replies
Posted : 16/09/2019 2:30 pm
Try new bearings as well.. My previous wheel creaked regularly, cleaning did help but new bearings sorted it for longer.
Posted : 16/09/2019 5:19 pm
Yep - I have to lube the inner sleeve and clean and grease the spline/contact surfaces now and again to silence it.
Posted : 16/09/2019 5:40 pm
thanks folks, it's good to know I am not alone in my pain . Will sort tonight and check bearings out at the same time 👍🙂
Posted : 16/09/2019 7:12 pm
I feel your pain. My Hope Evo 2 wheel is terrible for this. I have to pop it off and regrease regularly. If I'm lazy i can spray lubricant in from behind and it works for a while. It's the primary reason I shan't by XD ever again.
Posted : 16/09/2019 9:01 pm
