I think I might go for an ultegra 11-28 on my xc build with a triple up front.
Does that sound alright, what are you XC boys/girls using?
I'm using a 42-29 up front with a 12-27 Dura Ace at the rear.
one of the other bikes has a 34 up front with a 11-32 XTR
I'm using 36-28 up front and 11-32 at the back. Seems to work for most things and I've never run out of gearing.
on and on, PJM1974
are you both running 2x10 or 3x9?
one of the bikes is 1x9 the other is 2x9.
WAY too many duplicate ratios with a roadie cassette on an MTB, that and you're forever changing gear.
Much better to use a wide ratio 11-36 10spd cassette, and go dual ring (or even single ring if you're tough enough!) up front IMO. You still get the spread of gears, much less duplicate ratios, and you'll save more weight too.
Ok sound advice,
Thing is I don't want to fork out for a new drivetrain, just thought I could use my existing cranks and mechs.
If I go 2x9 what do I do, just lose a ring of the front?
10 speeds not an option at the moment as I've not got enough to buy a new drive train.
Thing is I don't want to fork out for a new drivetrain, just thought I could use my existing cranks and mechs.If I go 2x9 what do I do, just lose a ring of the front?
Yes.
Running 26/38 and an 11-32 here, it's nice. 2x9/10 is where it's at, triples are rubbish.
Thanks for the pic, nice bike BTW.
I'm sorted now will do 2x9
And thanks everyone for your advice. 🙂
22/36 chainrings.11-34 casette here. gears from 2 mph to 30 mph. that will do me
BTW I'm running 2x9.
This. I tried it for a while, but hated it. The close ratios aren't advantageous on an MTB, just annoying! 2x9 is a far better solution, I liked 28/40 with an 11-34. Now gone 1x10 with a 36 and 11-36.
Flame me as an old fart but I've been through all combinations of 3x9, 2x9, 1x9 and now on 3x10 new XTR which came on a new XC bike......3x10 is by far the best combination I've used. Have never ever gotten on with front mechs, always felt like I'm about to drop or break a chain, thus my efforts to reduce front changes by losing rings.
At this time of year I pretty much just stay in the big ring and go up and down that great big 11-36 cassette. Front changes are like a swiss clock. Granny ring weighs nothing, dont know what the advantage of losing it is. Unfortunately XTR is stupid expensive but it came on a bike.....
mcboo picture of your stupid expensive bike please?
I need my morning dose of eny.
Mine came with XTR 2x10, and I used XX last year. I just found (like you McBoo) that I was in the big ring 95% of the time, but often at the bottom of the block, with a rubbish chainline - and on a triple it's even worse. I find a single simpler, lighter and more effective. Personally I have no use whatsoever for a 22/24 type granny ring - I've not used one for 6 years. YMMV of course!
Only 'cause I'm a tart.
[img] https://lh6.googleusercontent.com/_lIQYQh49_C4/TZbJAkMVvII/AAAAAAAAAQc/YBt8ykLSSnc/s800/IMG [/img]
The bike wasnt all that expensive really when you price up all the bits that are hanging from it.
They are stonking value. Needs some lighter wheels.
Yeh the wheels look bling but not sure it's worth them putting them on this bike. Maybe something white/red/black from American Classic would have done the job for less and still looked outrageous.
mcboo me likey v.much...
and a great spec just looked at the website
What's it weigh in at?
about 23lb I think, is an XL.
three mtbikes geared differently
36/11-32
32/44/11-25
22/32/44/11-32
Kev
Tried 22/32/44 with a 12-27 cassette a few years ago, lovely for road sections (did use it for some road commuting) but too much shifting and not low enough gears xc.
Where do the none granny ringers ride? I do SS so not afraid to honk uphill but when I ride gears I like to spin to the top. Plus how the hell do you go up proper hills? 22x32 is nice to have in the lakes and similar hilly places.
WAY too many duplicate ratios with a roadie cassette on an MTB, that and you're forever changing gear.Much better to use a wide ratio 11-36 10spd cassette, and go dual ring (or even single ring if you're tough enough!) up front IMO. You still get the spread of gears, much less duplicate ratios, and you'll save more weight too.
true but an 11-28 ultegra cassette is not exact a close ratio cassette is it...
whereas and 11-21 would be!
11-28 is closer than 11-34. BTW there's not an Ultegra 9 speed 11-28 - it's SLX, Ultegras only come in 12-27 (which was actually what I tried).
All over the place. Local riding is Surrey Hills, but race everywhere. Raced 5 laps at Dalby on 36t single, done Afan, Margam, Mayhem etc, no problem! Did a 12 solo at Twentyfour12 with 30/42, barely even got out of the saddle.
IMO 22-32 is useless, so little momentum that you stop as soon as you hit anything. In 5 years I've not found anything I can't climb with a double that I would with a triple, and in 6 months of single ring that's yet to be a hindrance either.
for me having got on with 1x9 I like the look of 1x10 due to the 11-36 spread - no duplicates and simpler shifting
BTW way in 10speed you can get ultegra 11-28 assumed we were talking 10 speed as 9 speed is sooo obsolete 😉 😉
32/44/11-25
Good effort 😀
I can think of a few climbs that it's touch and go cleanable (for me) with 22x32 no chance with anything higher, long climbs with technical bits in the middle - or just long silly steep (back of walna scar). Being fitter would probably enable me to use higher gears but I'd have to get a lot fitter, there's time's I wish I had 22x34 not many tho. But you're a racer IIRC and I'm guessing speed means more to you than cleaning stuff - other way round for me 🙂IMO 22-32 is useless, so little momentum that you stop as soon as you hit anything
OP's 3rd post:
I am indeed a racer, but if I couldn't clean stuff I wouldn't stick with the limited ratios - I've not had to walk a climb in years, literally. And like I say, I've not found a single climb that I couldn't climb comfortably with a double that could be done with a triple, and single is proving fine, albeit a bit more of a grind in places! I am on a lighter bike than you (I expect!), which helps, and I'm possibly fitter, which also helps.
There's a climb near me which is steep, with a very steep rooty bit in the middle. Took me a few attemps to clean it, but once I got the knack it's fine. Higher gear is easier, you carry more speed, and don't stall on the roots. I've never seen anyone get up it, racer or otherwise, in a 22/32 type gear, you can't get over the roots. Admittedly it requires a bit more fitness to push the bigger gear, but like I say, I don't find really low gears any use at all. YMMV.
I'm guessing it's mostly
As you say more speed is def better on tech climbs but the stuff I'm thinking of there's no way I could charge up with 1:1 gear, lack of fitness 🙁and I'm possibly fitter, which also helps
Do it more, it gets easier 🙂
