X9 rear mech with 1...
[Closed] X9 rear mech with 10 speed?
[#4691508]
I'm toying with the idea of going 1x10 - I currently have a 2 x 9 setup with an X9 rear mech.
My plan is to get an 11-36 cassette, 10 speed chain and rear shifter, and strip off all the unneccesary bits and bobs.
Question is - will my 9 speed X9 rear mech have enough adjustment for 10 gears, or am I going to need a new rear mech as well??
Posted : 29/12/2012 1:13 pm
 Rich
[i]Apparently[/i] a Sram 9 speed rear mech will work with a Shimano 10 speed shifter.
Haven't tried it myself yet, but I will when I need to replace drivetrain.
Posted : 29/12/2012 1:23 pm
Really? I'm not convinced by that.
9/10 speed SRAM isn't interchangeable, so new mech required.
Posted : 29/12/2012 1:26 pm
yes they are not daft the bastards make sure you need to change everything or else why bring out a new "standard" ?
Its to maximise their profits whilst marketing tells you how much better it will be
Posted : 29/12/2012 1:28 pm
 Rich
I have read a couple of people say it works, due to having the same cable pull, but can't vouch for it personally.
Can't hurt to try before buying a mech anyway.
Posted : 29/12/2012 1:32 pm
9/10 sram are interchangable in some ways certainly. My mate has a 10 speed sram clutch mech on his dh bike and it's working perfectly with his 9 speed shifter. I suspect your mech will be fine with the 10 speed sram shifter and nothing to lose by trying it.
Posted : 29/12/2012 1:33 pm
Rich, I doubt very much that the Shimano shifter will work with the SRAM mech - they have different cable pull ratios, SRAM is 1:1 where Shimano is 1:2. But that's not what I'm asking, I'm asking if the X9 mech will have enough adjustment to work with a 10-speed cassette and SRAM 10-speed shifter.
Posted : 29/12/2012 1:35 pm
IT will have enough adjustment as a 10 speed cassette is as wide as a 9 speed cassette [ or you would need a new hub] - tbh i have used a 7 speed mech on 9 speed.
the issue is what the pull ratio is- ie linkage may mean that 1 cm of ull moves the 10 speed less than the 9 speed
I cannot answer your question - but it does have enough movement to cope
Posted : 29/12/2012 1:37 pm
Shimano have changed their pull ratios with Dynasis so it's closer to SRAM. Still be surprised if its truly interchangeable without bodging though!
Posted : 29/12/2012 1:44 pm
 Rich
It will have enough range, but that was never going to be an issue.
That's the thing though, Shimano 10 speed isn't a 2:1 pull ratio.
Edit: Check out first comment [url= http://www.bikerumor.com/2011/10/19/question-can-i-use-9-speed-derailleurs-with-10-speed-shifters/ ]here.[/url]
Posted : 29/12/2012 1:46 pm
i would go for a 10 speed X7 short cage mech....theres not a lot of difference between X7 and X9 as far as im aware other than 20grams and about £30....
although im sure everyone will jump down my throat and prove me wrong with that statement....lol
Posted : 29/12/2012 1:59 pm
