X9 Front Shifter
[Closed] X9 Front Shifter
[#2686095]
my X9 Shifter is playing up, the bigger trigger (to select high gear) is not returning to its original position after the shift..... I have been reading this is a common thing?
Is there any chance of a repair? or is ti a case of writing it off and buying a new one?
I did buy second hand off fleabay, it worked for a bout 4 rides!! Gutted now
Are X0 any better?
Posted : 23/04/2011 4:06 pm
My X7 does this too! I'm now so used to just pushing the lever back that I reckon I wouldn't get on with a properly working shifter. I also find that sometimes it doesn't release the cable like it should and it gets stuck inside the shifter a little.
Posted : 23/04/2011 4:31 pm
If it makes you feel better, I've handle similar trouble with my XT recently.
I have a LH x9 shifter in the parts box from my old bike if you want it? It has never suffered from the problem you describe. Drop me an email if you need it - £18 posted.
Posted : 23/04/2011 4:41 pm
trolling through the forums, It looks like a common fault.
will have to buy a new one now!
Posted : 23/04/2011 4:47 pm
I have x7 shifters on my year old Reign x1 they both don't spring back phoned Dales cycles in Glasgow where I bought it and they say their on their way out so getting them replaced under warranty
Posted : 23/04/2011 5:04 pm
i failed to fix one
x0 are nto that much better if at all I have x0 and x9 and cant really tell though x0 does change up further iirc on my FS and not ridden this year as i have been using the hardtail recently
Posted : 23/04/2011 5:21 pm
