Anyone else find that their X01/XX1/GX Eagle setup is noisier on rough trails.
-I've elimated chainslap on the chainstay, velcro rather than the harder spesh chainstay guard.
-Pulled the chain guide off, so no potential source there.
-Chain is as short as I dare go
Can replicate the noise statically if you release the chain tension with the button on the deraileur and swing the mech back and forward. Sounds like the B-Tension screw is smacking the mech hanger?
Have a spare mech to try to see if it dissapears.
Anyone else have any ideas?
Clutch blown? It happens - see whether the arm throws forward when pushed. It should be pretty solid.
Cheers Ben. Never found eagle mechs to much resistance to start with, will have a play later. Shame you can't modify them the same way as the 2.1 11spd stuff 🙁
