X-Fusiuon Hilo - br...
[Closed] X-Fusiuon Hilo - breakdown
[#3161351]
Tried taking the collar off on Sat to lube under the seal but disaster - being a numpty I did it upside down!
I emptied it of air but still had enough pressure for force the cetral column off and most of the oil came out.
I took it all apart as might as well by now - basically 1 nylon collar, 1 small alu collar and then 2 liner brass bushings.
Hydraulic oil has low viscosity prob 5wt as thinner than 7wt std shell fork oil I had.
put it all back together but having issues with equalising pressure in the inner column - got a bit of air trapped somewhere as the travel is fine but fully extended a bit squishy (i.e. moves about 5-10mm) 🙁
Posted : 19/09/2011 10:03 am
Try pumping it up while it's upside down with the remote lever pressed at the same time, that sorted mine out ok
Posted : 19/09/2011 10:17 am
Yeah I have done but fully compressed that but not quite there yet I think - will do it again and cycle through - cheers Khani 🙂 I presume you mean fully extended with lever pressed?
Posted : 19/09/2011 10:23 am
How did you get the collar off? I couldnt get mine to budge even with a strap wrench.
Posted : 19/09/2011 10:52 am
Send it back and say it [s]blew up[/s] exploded.
Posted : 19/09/2011 10:54 am
Got it from Deutsche.com so cant be arsed, might just buy a new frame and a reverb.
Posted : 19/09/2011 10:58 am
Yes, fully extended and upside down with the lever pressed
Posted : 19/09/2011 11:29 am
Scruff, what size is it and what's wrong with it? I'd be interested in having a crack as it if you are getting a Reverb instead.
Posted : 19/09/2011 11:33 am
Pipe wrench and inner tube wrapped around the collar
Posted : 19/09/2011 11:37 am
AndyL, that wont be until next year.
Foxy, tried that wouldn't budge.
Posted : 19/09/2011 11:46 am
I've got exactly the same problem - managed to lose some oil and now have the 5-10mm sag at full extension.
How much oil did you put back in yours?
Got some 5wt and 15wt fork oil in the garage.......
p.s - first post!
Andy
Posted : 19/09/2011 4:37 pm
Hi Andy
I filled mine up to the top - i.e. overflowed when I put the post back in but not sure that's correct - I'm gonna have to have a play - I'll try khanis trick and if not I'll empty some juice - I think air in the outer section has to be there as you have to pump it up to 25psi so prob doesn't have to be full!
Posted : 20/09/2011 7:54 am
The guy at X-fusion told me use 65ml of oil in my Hilo - he wouldn't tell me what type though, in fact he was pretty unhelpful. Initially he told me I wouldn't be able to disassemble the Hilo as it requires "professional tools". I'd already separated the upper and lower parts and finished cleaning them by that point.
Posted : 20/09/2011 9:26 am
ahh cool Steezysiz - I think at the weekend I'll do a full breakdown and use the 65ml of oil - I reckon its prob only low viscosity 5wt as my 7wt oil is still a bit sticky in comparison 🙂
From what I see you dont need any professional tools!
Posted : 20/09/2011 9:29 am
Unless an allen key is considered a professional tool, I don't think you do! Just to clarify, I didn't play around with the upper section air chamber at all - just took off the lower, cleaned it, replaced the oil and put it back together. It took a few goes to get the air pressure just right, but wasn't too hard.
Posted : 20/09/2011 9:33 am
Yeah me too, didn't touch the air chamber - I think I might do a quick article on it if I get it right 🙂
Posted : 20/09/2011 9:40 am
That'd be cool - it's a real shame X-fusion aren't more helpful when it come to manuals/user guides.
Posted : 20/09/2011 10:14 am
khani's tip (upside down, depressing the lever to balance the air) is what 2Pure recommend for filling Joplins so if they are similar design should get you somewhere close?
Posted : 20/09/2011 11:02 am
http://www.pinkbike.com/news/crank-brothers-joplin-review-2008.html
Got the theory now - I reckon I have air in the central oil reservoir - I guess emptying it and putting the 65ml in and then as you say cycle would be best 🙂 So fully extended upside down open valve then compress half way to remove air, turn back up, wait a while then extend - should remove any air?
Posted : 20/09/2011 11:15 am
I didn't compress or cycle it, just fully extended, upside down with the lever pressed and adding air sorted mine
I did have a link to a user guide and service instructions but it looks like they've been removed from xfusions website now 😥
http://www.xfusionshox.com/download_process.php?fp=ZG93bmxvYWQv&fn=SGlsb19TZXRfVXBfR3VpZGUucGRm
Posted : 20/09/2011 12:28 pm
Thanks - but I presume your had not been taken apart?
I presume you mean the setup guide?
Posted : 20/09/2011 12:31 pm
No, just a dead spot at the top of the travel from new
Posted : 20/09/2011 12:32 pm
Found this:
http://forums.mtbr.com/weight-weenies/x-fusion-hilo-658766-2.html
Sounds spot on 🙂
Posted : 20/09/2011 12:47 pm
Edit: Fixed
Need to top up the fluid to max and then pump to 25psi with valve open - cycle a couple of times and let it settle then test a couple of times 🙂
Posted : 21/09/2011 7:48 am
I wrote it up - Does anyone see any glaring errors in my method?
http://www.cyclistno1.co.uk/features/maintenance/x-fusion-hilo-service.htm
Posted : 26/09/2011 9:27 am
Looks useful.Mine had soms rotational play from new, do you think the brass bits can be adjusted or put back in some other way to help ?
Posted : 26/09/2011 10:40 am
I dunno - Mine has a bit of twist still TBH - I think the bushings are not a majorly close fit - I wonder whether the new 120 post has closer tolerances? I dont think the little bit of play you describe is a sign of a fault from what I have read?
Posted : 26/09/2011 11:00 am
foxyrider - did greasing under the seal improve the performance?
Posted : 05/10/2011 9:58 pm
@ foxyrider - really nice article, definitely a few things in there that would have made my go a bit cleaner! Just out of interest, did you buy the red ano bits seperately, or did you get them with the post? Me likey!
Posted : 05/10/2011 11:11 pm
Are you all happy with these posts or not ?
Posted : 05/10/2011 11:25 pm
Just received mine ysterday, the up-stroke is sluggish/hesitant is it simply a matter of breaking it in or do i need to boost the pressure?
Posted : 02/11/2011 11:25 am
It takes 3-4 seconds for mine to fully return. Is this the same as everyone else's?
I tried to top up the air just in case but my 2 shock pumps wouldn't work for some reason. I then tried depressing the valve core very gently to make sure that it was moving ok and oil started to come out. I didn't do anything else after that in case I blew it up. Is this normal?
Posted : 02/11/2011 12:02 pm
3-4 second return isnt right. Try more air as per instructions and some chain lube or whatever around the seal.
Posted : 02/11/2011 12:14 pm
Ok just tried increasing the air pressure whilst pulling the lever, worked a charm 🙂 no delay just Poppins straight up.
Posted : 02/11/2011 2:43 pm
