X fusion vengeance ...
[Closed] X fusion vengeance help
[#4128761]
Only getting half travel on my 170mm OEM vengeances. Only adjustments are rebound and an air valve on the bottom leg. I thought it might be some kind of opposing iston job to set preload but don't want to over pressurize it. Internet has very little info. Anyone have any experience? It's a medium spring and I'm 70kg so should be fine.
Posted : 03/07/2012 9:25 pm
Quite a lot of tech info on their website. You might find something there if you didn't look already.
Posted : 03/07/2012 10:10 pm
No pertinent info on the website unfortunately. May just have to buy a soft spring or play with bathe pressure on the unknown valve.
Posted : 03/07/2012 10:47 pm
 ianv
I don't think that it will be the spring, I am lighter, about 65 kg and I get almost full travel from the stock spring.
Posted : 03/07/2012 10:54 pm
Manual says 40-200psi, what do you have?
Would suggest starting at 40 and working up.
Posted : 03/07/2012 10:58 pm
Cheers, will crank up the pressure!
Posted : 04/07/2012 1:36 am
no... he means you should start at a low pressure and work your way up.
less is more.
Posted : 04/07/2012 1:48 am
Less pressure = no rebound damping more = less travel. Think service may be needed
Posted : 04/07/2012 8:52 am
