X Fusion slants.......
[Closed] X Fusion slants....confused!
[#6374872]
I have been offered a practically new set of X Fusion slants as I am building up a 650b hardtail. Seller claims they will take both 26 and 650b wheels. After some internet research it seems some say yes, some say no, others say a spacer has to be fitted at factory. Their own website claims 26" only. I'm confused to say the least.
Anyone got a set with 650b wheels fitted that can confirm, most posts I have read are pre 2014 and are usually people who are either waiting for an ordered set or don't even have a set.
Sonnyjim
Posted : 30/07/2014 6:19 pm
I have a set not running 650b currently but have tried them with a 650b wheel and the spacer fitted and there is plenty of clearance
Posted : 30/07/2014 6:22 pm
Ok so a spacer is needed, does this come with the fork or is it bought separately or factory fit only.
Oh and is it easy to fit?
Posted : 30/07/2014 6:30 pm
I have a pair on 26" wheels.
With a large volume 650B tyre fitted it will rub on the crown at full compression. A 10mm travel reducer spacer can be fitted to avoid this. This was the information I was given for 2012 onwards forks.
Posted : 30/07/2014 6:34 pm
Ok getting somewhere now, rab5474 was the spacer supplied with the fork as new and did you fit/remove it yourself?
Posted : 30/07/2014 6:44 pm
I bought my forks new, no 10mm spacer supplied, as the standard adjustment is in 20mm steps with the ladder pin. Should be available as a spare part if not included.
Posted : 30/07/2014 6:47 pm
I had a set of Sants since November, 26" with 26" wheels and a Magic Mary on the front. In the alps enough mud got between the tyre and the arch to lock the wheel. On that basis I'd say running a 650b wheel would be a no no.
Posted : 30/07/2014 7:16 pm
But, the distance between axle and arch is what limits the wheel size, surely? How would a spacer which affects travel change the length of the lower leg??
Posted : 30/07/2014 9:18 pm
X Fusion changed the lowers casting on the Slants for the 2014 models. The pre-2014 lowers (which have the Syntace axle) will not readily clear a 650b wheel at all. The 2014 lowers (which have a Maxle style axle) are exactly the same as the lowers for the Sweep (their 650b fork) and will take a 650b wheel fine.
The Sweep has a different offset in the crown in order to suit 650b better than the later Slants but both will take 650b wheels fine.
Posted : 30/07/2014 9:27 pm
 SOAP
I've got 2.4 trail kings on mine and you can still get a bus between the tyre and the arch.
Posted : 30/07/2014 9:28 pm
Ok, I have 2014 Slants and my brother has 27.5 Pikes. Clearance with his 27.5 wheel in both (Bonty XR4 2.3 - comes up big) is roughly the same in both, despite the slants being 26". I tested this by putting my thumb between the brace and tyre on both forks.
Posted : 30/07/2014 9:30 pm
Abigale has the 2014s on her Enduro. They can take both sizes. There is loads of room above a 26 inch Butcher tyre
Posted : 30/07/2014 9:31 pm
Clearing the brace on the lowers is not the problem its wether the tyre hits the crown of the fork uppers, let all the air out and compress fork through all of its travel then check tyre clearance, my 36's had 13mm clearance with a 2.25 Ardent 650b but my 32's touched with about 25mm to go to full travel.
Posted : 30/07/2014 9:35 pm
Yup, mine have the syntace axle.
Posted : 30/07/2014 9:38 pm
Check with upgradebikes...like I did and speak to Martin.
Posted : 30/07/2014 10:13 pm
Indeed - if it's the 2014 it will still want the travel limiting to avoid tyre/crown, but 2013 won't clear at the arch no matter what.
Posted : 30/07/2014 10:28 pm
