WTD - SRAM X9 Jocke...
[Closed] WTD - SRAM X9 Jockey wheels
[#949492]
Hi,
Anyone replaced their X9 jockey wheels on SRAM rear mech ?
cheers 😀
Posted : 13/10/2009 9:10 pm
[url= http://www.dotbike.com/productsP3992.aspx ]BBB ones ?[/url]
Posted : 13/10/2009 9:15 pm
Stuey - not sure what you mean ? 😕
Posted : 13/10/2009 9:22 pm
I looked into this. You can either have BBBs, which are about 12-15 GBP, or the SRAM, which are about 20-25, depending. I don't think you have any other options. Choking price for some toy plastic wheels, IYAM.
Posted : 13/10/2009 9:26 pm
I filed the tab off the cage on mine so I could use a normal centre mounted top jockey wheel, the position is obviously slightly different but it works perfectly.
Although I only did this as I needed to get up and running and had some spare spangly gold ones laying around doing nothing. 🙂
Posted : 13/10/2009 9:45 pm
 rj
If there the same as X0, then I just replaced mine with KCNC which seem to work faultlessly and come in a variety of colours.
Posted : 13/10/2009 10:43 pm
The BBB ones seem very good so far, I found the plastic clamshell did clog up with mud but it takes a couple of minutes to sort out every few hundred miles, and the bearing itself is well protected. Seem better than the SRAM ones to me.
Posted : 13/10/2009 11:27 pm
