Would be interested in details of the setup you used if possible then NW. If it's already within this thread then apologies
I used 20" bmx tubes.
Sorry,double post.
guitarhero - MemberWould be interested in details of the setup you used if possible then NW. If it's already within this thread then apologies
It is but it's buried! Pretty simple but it did take some faff the first time. I used 4 or 5 wraps of jiffy foam cut to about 60mm wide, to bulk up the centre of the rim to aid inflation (otherwise there's a massive gap between tyre and rim and it needs a lot of luck to get it to inflate). NOT the bead, I didn't want the tyre sitting on foam. This is pretty much the same thing that I did with tubes.
(I wasn't totally happy with this foam, it compressed over time so I had to "top it up". It did stabilise but that was extra faff. It did work fine but there might be better options)
Over that, I put a wrap of 75mm PVC tape- just fat electric tape really. That went right from bead to bead and gave it the seal- the foam's completely covered. I removed a little extra foam from around the valve hole so that the valve doesn't sit on foam. Then I reinforced it with a couple of extra layers of tape there, then fitted a nice fat schrader valve- I think it was these ones:
So basically it's just like normal tubeless taping on a stans rim, except with a layer of foam in the middle. You can do something very similiar with plastic pallet wrap instead of the tape, but I had to redo the wrap every time I fitted a tyre so that got old, this is semi-permanent and allows easier tyre swaps.
Thanks NW. Might give it a go but at the moment the ratio of faff to ride time on this bike isn't favorable, so will ride some more first.
Do you know the axle to crown and offset of the Dune fork btw.
Measured at approx 460 mm a to c. Finding the front end a bit low compared to my Stooge, and have run out of steerer.
Just a heads up to anyone thinking about those £89 Carbon fatty forks that require an RDS wheel...
They don't show at PX, but On One lists 6 Fatty Front wheels that are RDS for £55.
http://www.on-one.co.uk/i/q/WFOOFAT/on-one-fatty-front-wheel
A bit cheaper than buying one of those RDS Fatsno hubs from CRC and then getting a wheel built up.;)
slimjim78 - Member
What price did you manage to get them for?
£159.98 with two *free* Maxxis fatty tubes 😀 They even came in little drawstring baggies!! :lol:[url= https://c3.staticflickr.com/6/5514/30395022090_a04ea4a138_k.jp g" target="_blank">https://c3.staticflickr.com/6/5514/30395022090_a04ea4a138_k.jp g"/> [/img][/url][url= https://flic.kr/p/NiUr81 ]IMG_1771[/url] by [url= https://www.flickr.com/photos/145571820@N03/ ]Paul Tarrant[/url], on Flickr
The bags are ace, they do let dirt out if you put manky shoes in them though
Northwind - Member
Haven't dreamed up a use for them yet. Thought they might be good for helmet/glove storage 🙂
I did mine with the backer rod method and Floaters yesterday. Admittedly I used a compressor but they been ridden twice today and still holding air.
Finally got to the end of this very persuasive thread.
I called in to GO yesterday to have a look at the dune and they were happy for me to have a pedal up the the isles ( and a sneaky bit of gravel around the tents when out of sight ) And yes I did find myself with a big silly fat bike grin when I got off it
Got talking to the Young mechanic who told me that he had recently been to nottiningham (GO HQ? ) and seen next years model with a dropper, yari (presumed Bluto) forks and better brakes.
If he's correct I reckon I will be joining 'fat club' next year 😀
Awesome, looking forward to seeing what they do with the upgraded model. If it comes in at Fatty pricing then O-O will be worried..
OK, I'm in. Large Dune purchased last Sunday. Plan to pretty much run as is for the moment, just swapping over the saddle & bars to save a bit of weight.
First impressions are very good. Incredible value for a £500 bike. Gear change obviously not quite as slick as the X01 I'm used to. Personally I didn't find the cable discs too bad; commuting on a road bike or Brompton means I'm used to slowing down rather than stopping.
Handled and climbed much better than I anticipated, just a bit slower on the flat. Can't wait to get out on it again this weekend.
Congrats ssnowman, a wise purchase.
Although you must be king of the bimblers if you find those brakes acceptable 🙂
If really does excel at climbing and decending. Have fun extracting maximum mind bending grip on the corners.
slimjim78 - maybe I am king of the bimblers, or maybe I just like living dangerously 😉
Possibly the latter, as i'm yet to meet a greater bimbler than I
Ssnowman, I've got a set of Deore brakes still waiting to be fitted. It all works fine for bimbling as it is!
Just put my mudhuggers on the dune. The front one needed to be basically melted down to make it fit, it's a square peg in a round hole. Seems like it'll work but it's really, really ugly. Quite bummed tbh, it wasn't cheap but it's very fork specific
Pics!
Close to pulling trigger on set of Blutos..
CTBM has a couple of 80mm sets at £349.. bloody credit card may feel my wrath again
****ing thing has reacted to the uglyguards by exploding its reverb. This is what real life is like, Dune, it's not all handmade wheelsets and specially imported tyres, sometimes I'm going to fit hideous crap to you just to keep my arse dry- get over it.
You can grab a Fatty Trail from DFS for £850 (it's 15% off everything in store) for as long as thE scout's bonfire embers still burn from last night, use 72NDSCOUTS15.
Hi all, another Dune convert here! Crazy good fun, like someone said a bit like a BMX with massive wheels...takes me back to my yoof!! Not getting rid of the Norco sight just yet but still loads of fun, and my kids keep pinching it!
Generally happy with how it runs, but (and you know whats coming!) a friend recently bought, and now has changed their mind (and willing to sell it to me for a great price as its been on a bike / no packaging) about quite a nice M7000 1x 11 SLX group,
Question would be (and have read all 44 pages trying to get the answer exactly!!) regarding the drive train portion(brakes yep will just swap out) how much of this can i use and how much needs replacing...from what i can gather its all about a 175mm Aeffect crank and flipped ring, any of the Shimano crank / ring usable? Can just sell on if not i guess..Basically trying to guage how much of this Group set is usable and minimise extra parts on top of this...Guessing good to replace the BB / bearing at the same time, or does that come with the aeffect anyhow? and does the new cassette just bolt on in replacement to the old one? Or have to swap hubs...Issues with 1x11 and wheel clearance on a 4 inch tyre?.Sorry i know this prob been answerred in a fragmented way over the 44 pages but just cant consolodate all the info! Maybe this can be the definitive 1x swap out answer!! Again thanks in advance, this thread defo pushed me into trying the fatbike and really glad i did (and so are my kids, haha!)
Out on the bike later being as its such a nice day, will post some pics....Cheeers dudes
You ought to be able to use everything apart from the cranks. You don't really need to replace the OE cranks, they're heavy but decent enough, you could just put a new ring on those (I'd probably have replaced them anyway because I'm a weight weenie, but mostly I did it because I desyroyed one of the crank arms through carelessness...)
1x has decent clearance even with a 4.8, and the cassette is a straight swap so it should all be pretty pain free.
ahh amazing thanks so much for the reply!
This thread defo all you need to know about these bikes!
So if i used everything apart from the SLX cranks, an Aeffect crank would work with the SLX chain etc? Or buy just the Aeffect crank and put the SLX chainring on that, if it is the same bolt pattern? In my head it all works but never sure about cross brand chain / chain ring / crank compatability etc! Seems like some chains are designed to only work with same model chain ring...but could be wrong.
I can use all of the OE stuff coming off the Dune on another fat build for the kids so nothing going to waste...
Thanks again!
The aeffects are "cinch", they use a direct mount chainring so not compatible, they need a raceface-spec direct mount (plus side is, that means you can go really small if you want) I'm not sure what BCD your SLXs will use, the stock Dune one is a very trad 104bcd chainring so most narrow/wide rings will fit (and work fine with the SLX, I think). Probably makes most sense to sell the cranks with the ring, and buy a cheap narrow/wide for the stock cranks- or go all new with the aeffects or whatever
(other cranks are available but the 170mm rear version of the aeffects fits the Dune like it was made for it, and seems really good value. Not to mention, uses a proper bottom bracket, none of that sram pish)
What NW said /\
The Cinch chainrings are great, albeit not exactly cheap.
1x11 Shimano set ups theoretically have less tyre clearance than 1x10 or 1x11 SRAM as the extra cog hangs over the back of the cassette on Shimano set-ups. But i'm yet to hear of anyone not having enough clearance on a Dune, certainly with 4.0s fitted.
I run 1x10 so can't offer a definitive assurance that 1x11 Shimano will work - but NW seems to think to, which is jolly good.
I've the Aeffect crankset on my Singular Puffin, nice piece of kit. Worth reading the instructions and measuring the width of the BB, got to be 98mm or very close. I didn't, had missed a spacer so needed to remove the cranks. Guess who hadn't got a crank puller? 🙄
Anyway, it's worth getting an ISIS crank puller.
The Aeffect cranks are direct mount but I think someone, might be Raceface themselves do a direct mount to 104BCD converter.
I purchased a new 28t Cinch chainring from Slam69 for £34. Its a blackspire one but £15 cheaper than the standard Raceface version. I have an absolute black oval one on my fatty which is beautiful but i seem to remember being very expensive.
Have to say the Aeffect cranks are great value for money, I find the cinch system pretty good. I like running smaller chainrings and the small oval system works brilliantly on a fat bike. You can climb just about anything! Only issue is running out of gears on crappy fire road descents. But who cares about that.
yeah I run an Absolute Black (although its green) 30T (i think, might be a 32T) oval and its a lovely bit of kit. I'm thinking of dropping 2 teeth though, as im currently riding very infrequently and fitness levels have dropped.
Not sure the Dune would take any bigger in oval format, with the ring flipped it runs close enough to the chain stay.
Aeffects would be perfect if they could be removed with a big ol' allen key - I don't like using dedicated extraction tools.
So i had my first fatty puncture yesterday, through my Maxxis Mammoth. I got back from my ride to see a thorn stuck in the front tyre. I'm not tubeless yet, so washed the bike then pulled the thorn out. It was about 15mm long. Tyre slowly started going down - at least I get to fix it tonight in the relative warmth of the garage rather than out on the trail!
Not sure it's a dedicated tool, I already had a crank extraction tool one of each size that had been redundant for years. Not had any issue removing myself. Just ordered some cinch sixc's for my skinny as well now. Much better than the joke of a hope crankset. But that's a whole new thread I guess
Many thanks again guys for all the info...
Really appreciated... 🙂
Today's ride, bike is almost there
[URL= http://i73.photobucket.com/albums/i220/HolysToy/Mobile%20Uploads/IMG_4189_zpsul5rpm2x.jp g" target="_blank">
http://i73.photobucket.com/albums/i220/HolysToy/Mobile%20Uploads/IMG_4189_zpsul5rpm2x.jp g"/> [/IMG][/URL]
Nice shot.
How anyone couldn't fall in love with a bike that looks that daft is beyond me.
It's a tough one.. i have to admit it looks bloody great... but only in a cartoon way, like them pics you'd get on old T-shirts...
I still can't get my head around it as a bike to ride though
Yeah, it does look a bit like something Mint Sauce would ride (thats cool!). Have you ridden one?
It's been said a thousand times already, but the feeling of extra grip and sure-footedness paints an ear to ear grin on your face.
Has become my sole MTB because it does real world riding so well - and simply.
Unless you're a full on air bandit wanting to launch of every lip then it just makes great sense as an off road tool.
Did a quick slideshow vid of getting the dune up tubeless.
Decided to try using that self-adhesive weather strip you get for draughty doors etc.
It worked really well, except for the tubes I had which were Schwalbe 24x2.5" ended up being a little too narrow initially. I found that I needed to fill the valley in the centre of the rim as the tube pulled itself into there making it too short to overlap each edge.
The solution was a narrow strip of camping mat between the outer weather shield strips.
You could argue against using the weather strips at all, and this is what I did in my Wazoo which worked great, but a benefit to the strips is that you can be quite accurate in terms of placement.
nice idea. I've been experimenting with backer rods and they're a bitch to keep in place with tape/spray adhesive.
Still in the 'new toy' phase with my Dune, so enjoying the change, but I find the bike too short for stand up climbing, and the front end a bit low for descending.
I've ordered a 28T front ring so I can sit and spin more (which is comfortable), but with the pre-cut steerer I don't see how I can raise the front end enough. I tried a longer stem but that put my weight too far forward which made the bike rougher on my hands.
My gut is saying go all in and get a Surly ICT in medium and move the bits over.
Anyone ridden both?
Sounds like it is too small for you tbh....
El Guapo Outlaw 31.8mm stem, 45mm reach, 7 degree rise is ~£22.50 at the place with yo-yo pricing.
http://yojimg.net/bike/web_tools/stem.php says it has ~8mm more reach and is ~9mm higher than the 35mm Corto with the Wazoo's 69.5 degree head tube angle.
I've put a Ritchey Comp stem on, 30 dog rise available in various lengths
Love the comments! ^
Not sure if he has ridden a Dune but RoverPig of STW fame has an ICT so I'm sure can give feedback on what a great bike that is.
Riser bars Shirley?
