Wolf Tooth/OneUp Dr...
[Closed] Wolf Tooth/OneUp Dropper Remote Owners
[#11417107]
For anyone that owns either a Wolf Tooth or OneUP dropper remote - when you remove the clamp, are you left with the SRAM style fitting as in the pic below? Where a single bolt from above can attach it to a SRAM-style clamp? (Sorry if I've explained this badly)
Have a couple of brakes with the style of mount below, but not SRAM, so the MMX style mount won't work, just need the two bolt holes (or just one)
The BikeYoke remote picture below shows what I'm after
Posted : 07/10/2020 1:06 pm
I think this pic answers my question for the OneUp V2, it looks like what I'm after
Posted : 07/10/2020 1:11 pm
Wolftooth no, you needed an adapter at about 20 quid 😤
Posted : 07/10/2020 1:24 pm
Right.... that rules Wolf Tooth out then 🙂 They're already 20 quid more than the OneUp, even though they are meant to be nice to use
Posted : 07/10/2020 1:26 pm
Yes.  I have a OneUp V2 lever mounted to a Hope Race Evo brake lever using Hopes SRAM compatible clamp.  I ordered the lever with the band on clamp in case I ever need it then mounted the bare lever
Posted : 07/10/2020 1:28 pm
yup the one up has 3? tapped holes
Posted : 07/10/2020 1:33 pm
Rubber_Buccaneer
Nice one, that's my exact plan, with a possible move to a Formula adapter on the cards also, thanks
alan1977
Thanks
Posted : 07/10/2020 2:02 pm
Wolftooth ergonomics are ok, although I would hardly think ground breaking. My only comparison in Bikeyolk, and I didn't really notice a difference for just one ride. The breakaway bolt is an ok feature I suppose, but the way it goes together is quite fiddly. Neutral review.
If I purchased again I'd go OneUp or Ritchey cheapie
Posted : 07/10/2020 2:19 pm
Ive just swapped my one up lever (which broke) for a wolf tooth light action one. Its way better but also way more expensive. You can specify which attachment when you buy it so easy to get the Sram compatible one. The Sram matchmaker version is slightly cheaper that the regular bar clamp version (as it should be).
https://www.wolftoothcomponents.com/products/remote?variant=20300121605
Posted : 07/10/2020 3:05 pm
Yup, OneUp has 3 holes, mounted mine to a Hope Tech 3 lever with no issues 🙂
Posted : 07/10/2020 3:30 pm
Wolf tooth one much nicer imo
Posted : 07/10/2020 8:25 pm
