Wobbly sram crank a...
[Closed] Wobbly sram crank arm help
[#8290273]
Hi, I've got a sram force single ring chainset and just noticed the driveside crank arm is loose... Anyone had this before and can it be fixed? I've taken the chainset off and when holding the axle the chainring doesn't move but the arm has quite a bit of play. I can't see any bolts to tighten up and am thinking it may be knackered.
Sorry if this is a bit garbled, at work on phone.
Posted : 16/01/2017 5:08 pm
