Wobbly SKS Bluemels
[Closed] Wobbly SKS Bluemels
[#10343156]
I've got a set of these on my charge Plug. Rear is solid as a rock, but the front wobbles all over the shop.
Anyone else suffer this, and is there a decent solution? I'm thinking of filling the attachment brackets (fork end) with epoxy as I think the 'float' in them is what allows the movement.
Cheers.
Posted : 20/11/2018 1:25 pm
yes it's the safety breakaway fixing on the front being crap IME - it allows too much play. I had some clips and stays from some SKS chromoplastics which are much more solid connection but still with the release feature - not sure if you can get them separately though. If you fill the clip so that it won't release then you might regret it. I thought they were superfluous until a stone got jammed in the front and the guard crumpled up to the fork - messy but saved an OTB.
edit - these:
https://www.sjscycles.co.uk/mudguards/sks-secu-clips-for-front-mudguard-stays-per-pair/
+ some regular stays. If you can't find some then I might have a used pair I can send you.. somewhere
Posted : 20/11/2018 1:50 pm
