wobbly Hope hub
[Closed] wobbly Hope hub
[#491550]
My rear Hope hub has a bit of play, in the same way a wheel wobbles with loose cups/cones. It's a Hope Sport I think, stock on a Whyte 46. It's done good mileage and has been serviced but yet to put new bearings in. Before I do so, is there anything else that could cause a bit of play?
Posted : 22/04/2009 9:49 am
Broken axle?
It will be the bearings I bet
Posted : 22/04/2009 9:59 am
At least I will be able to see a broken axle pretty clearly. I hope it isn't - off to Spain next week 😮
Posted : 22/04/2009 10:00 am
loose skewer
all the spokes loose
ie [b]no[/b]
Hope Sports I think, were discontinued by the time the Whyte 46 came about. Its probably a Hope XC, unless of course, the wheel was sourced elsewhere.
Posted : 22/04/2009 10:04 am
The wheel is the stock wheel on a 2006 Whyte 46
Posted : 22/04/2009 10:05 am
bet the axle is broke, happened to mine, breaks just in from the freehub body - so doesn't look from the outside like its gone. doubt its your bearings as it would be very rough to spin if there far enough gone to wobble
Posted : 22/04/2009 10:10 am
Better check pretty bloomin' quickly then. Enough time still to order a new axle. Thanks
Posted : 22/04/2009 10:12 am
