Wobbly back end
[Closed] Wobbly back end
[#6860728]
Riding my hardtail the other night the backend felt a bit squirmy especially cornering under power.
I checked all the usual stuff, tyre pressure is OK, QR tight etc. couldn't find anything obvious so just put it down to my imagination.
But looking again tonight at the bike in the garage there seems to be quite a bit of flex side to side in the rear wheel, if I grab the wheel between the chain stays I seem to be able to push and pull it a bit.
The wheels are new (only a handful of rides old) Hope Hoops Arch EX 29ers , could it be that they need a re-tension already?
Posted : 13/02/2015 10:55 pm
 m0rk
Check the replaceable dropout (if you have one)
Posted : 13/02/2015 10:58 pm
Wobbly back end - do some squats and eat less pies.
Posted : 13/02/2015 10:59 pm
Sounds like a tension issue for sure.
I bought brand new Flow EX and after a couple of rides I had enough, loose spokes and poor tension, plus gritty rear bearings.
I returned to Hope and they came back perfect, I'd get them sent back and Hope will sort you a proper re-tension for sure.
Posted : 13/02/2015 11:04 pm
 JAG
It could be wheel bearings shot - sounds too soon but the symptoms are right 🙁
Posted : 14/02/2015 12:18 am
I had a hope wheel that had extremely low tension right from the box. It felt terrible till I re tensioned it after noticing a couple of loose spokes.
Posted : 14/02/2015 12:48 am
Cones come loose??
Posted : 14/02/2015 12:00 pm
Possible loose bearings
Possible loose spokes
Possible broken axel
Posted : 14/02/2015 12:09 pm
