Anyone Avalanched a...
[Closed] Anyone Avalanched a fox RP23 shock before?
[#6860743]
Looking to go down the CCDB route but a tuned shock seems cheaper than an infinitely tuneable one
Posted : 13/02/2015 10:59 pm
can u do an RP23?
I did a DHX air (bough a s/h one with a blown reservoir)
its really is impressive
but you will get stung for taxes so it doesnt work out as cheap as you think, still cheaper than a ccdb though and they are very helpful with what your needs are and setup etc
Posted : 13/02/2015 11:46 pm
cheers for that
Yeah they change the BV to be more speed responsive and move HS compression to the propedal lever
Just curious how that would work on a fivespot
Posted : 14/02/2015 12:12 am
I see, the HS compression doesnt work the same as the propedal, so you lose the full lockout but it pedals better than before and is much more controlled descending
Posted : 14/02/2015 12:19 am
I've just picked up a brand new CCDBA for £230!
I was going to go down the Avalanche route but realised I could pick up A Cane Creek for about the same price as sending my Fox shock to the states, give or take a few quid!
Posted : 14/02/2015 1:43 am
Main concern in fitting a CCDBa to a 2011 5-spot is the lack of space
I've seen that you can put an inline in (with an offset bush) but don't think anything bigger will fit (hence the frame changes they did for 2012)
At least with an Avvy mod the shock will fit and they can hopefully tune it to the leverage ratio / keep the damping low
Posted : 14/02/2015 8:04 am
CCDBA for £230?
Posted : 14/02/2015 9:27 am
Yep,eBay is your friend!
Came from a German eBay shop.
Posted : 14/02/2015 10:54 am
