Wobble in Hope rear...
[Closed] Wobble in Hope rear Wheel???
[#780542]
I've got a 6 month old hope pro 2 on my Whyte 905, its gained a bit of play, only a couple of mm at the rim but its irritating!
Any thoughts on what it could be?
Posted : 12/08/2009 10:53 pm
uh, you need new bearings!
Posted : 12/08/2009 10:55 pm
Yep,new bearings,5 in total.Just done mine due to having the same issues as you.
Posted : 12/08/2009 11:00 pm
 nbt
Depends what you mean by wobble - if the rim rocks when you hold it and twist, then bearings as suggested. If the rim moves as the wheel spins, then it's out of true and needs re-trueing
Posted : 12/08/2009 11:01 pm
FIVE ?? Most Hope rears have 2 main bearings that cause the wobble and 2 more in the freehub that usually wear slower...
Posted : 12/08/2009 11:02 pm
It will be unlikely that the freehub bearings are gone, probably be the main bearings. I found my non drive side went first for some reason.
Posted : 12/08/2009 11:08 pm
