Will these headset ...
[Closed] Will these headset bearings fit ?
[#8471319]
The bike is a Specialized Camber Evo 2015.
The specs say the headset is a:
1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
Will these bearings fit ?
http://www.chainreactioncycles.com/cane-creek-cartridge-bearings-s2-s3-zs2-is2/rp-prod11266
Posted : 26/04/2017 12:01 pm
May fit the top, deffo not the bottom as they are for an ID of 1 1/8 and yours is tapered..
Easiest way to check is to drop out the existing ones, only takes a few minutes, and they'll be marked up with sizes 🙂
Posted : 26/04/2017 12:06 pm
I just put one of these in the bottom of a 2016 Enduro headset - so it's most likely the one you want too...
http://www.superstarcomponents.com/en/type-2-headset-bearings-1-5-or-tapered-45x45-degree-x1.htm
Posted : 26/04/2017 12:12 pm
What about this
upper
http://www.pearcecycles.co.uk/product/1425
lower
http://www.pearcecycles.co.uk/product/1426
They're not cheap though!
Posted : 26/04/2017 12:17 pm
that would be good if it fits and a lot cheaper than the one at Pearce cycles
Posted : 26/04/2017 12:18 pm
