Hello
Will the evolution hobby nic folding tire work with stans tire sealant ?
-or should i look at another sealant ?
Yes. It will work.
I have been using Stan's with Noby Nic Evo's for the last 4 years with no problems at all. You may get a little bit of side wall seapage at first but that soon stops as the sealant coats the inside of the tyre.
Yes.
Working fine for me.
I've had Nics on my bike for years, works fine.
That's what I'm running aswell. Take the opportunity to experiment with your tyre pressures, NN go from pretty rubbish to pretty good if ypu get the pressure right.
Been fine with mine. Just wondering why you'd think it wouldn't work as I'd never even have given it a second thought?
A tubeless ready tyre will work with any decent sealant , Stans is probably the most common for the reason that it works well .
Yes. Even the liteskin Schwalbes will seal with Stan's and a bedding in ride. (not that I'm saying Stan's is great, just what I happen to have used).
