Will new top cap fi...
[Closed] Will new top cap fix reverb movement?
[#7301875]
Hi,
As the title says my rock shox reverb has just started to move around a bit.
Will just replacing the bushing top cap fix that or will I need more parts ?
Posted : 31/08/2015 10:00 pm
In which direction?
Rotational- probably need new keys if it's really bad.
Up and down- likely air in post, needs an internal bleed
Side to side/fore and aft- probably the bush(es), one in the to cap, one lower down
Posted : 31/08/2015 11:08 pm
Stealth or externally routed?
Movement, as in forward/backwards slightly; sagging under load, or left right when holding/twisting the saddle?
Posted : 31/08/2015 11:09 pm
Beat me to it 🙂
Posted : 31/08/2015 11:10 pm
It's externally routed. It started off with a very slight back to forward movement and now has gotten worse.
I wasn't aware there was a lower bush ?
Posted : 01/09/2015 6:07 am
You need to buy the big nut at the bottom of the shaft, comes with bush installed. Can be had from Germany for about 25 quid.
Posted : 01/09/2015 7:17 am
I just replaced the top cap and it has fixed the forward and back movement but now I can twist the saddle side to side a little bit. What could this be ?
Posted : 01/09/2015 7:24 pm
Did you replace the same keys that were in there before? If so there shouldn't be any more rotational movement than there was. If might be that you weren't looking for it?
Posted : 01/09/2015 8:53 pm
Yeah I did replace with the same keys, They had the 3 strikes in them but i do feel that there is a bit extra rotational movement than there should be. would putting the next size keys up be an option ?
Posted : 01/09/2015 9:21 pm
I have wondered that but assumed that they'd have some sort of procedure in the factory to start with the biggest key size and work their way down. Most reverbs (and most other droppers I've tried) have some sort of rotational play, is it actually going to be something you notice while riding?
Posted : 01/09/2015 9:53 pm
Fair call there Mate,
I will check it again in the morning its probably not as bad as i think. It is way better than what it was so i should be happy with that.
Cheers for your help
Posted : 01/09/2015 9:57 pm
You're welcome, hope it's ok!
Posted : 02/09/2015 1:02 pm
