Will I die - bike &...
[Closed] Will I die - bike "fixing" BB bearing content
[#3110076]
In attempting to fix the slight grind on my bottom bracket, I've taken out the angular contact bearing to give it a good clean and re-grease.
In the process, I've accidentally removed the "cage" holding the bearings in place between the races. I can't get this cage back on, so the bearings are rolling loose inside the race. If I roll it round long enough, they all congregate together, and then there's a lot of play between the inner and outer race.
Do you think I'll die if I use this for one (shortish - 10 mile) ride tomorrow until I can get a new bearing set or am I likely to fubar my bottom bracket and crankset?
Posted : 03/09/2011 12:12 pm
If the bearing faces are disposable - what's the worse that can happen - can you chuck a few more in for good measure(not too many though)
But if they can come into contact with 'expensive' bits I'd be wary.
Posted : 03/09/2011 12:23 pm
