Will a Sram medium ...
[Closed] Will a Sram medium XO mech cope with 44/29?
[#683127]
Following on from [url= http://www.singletrackworld.com/forum/topic/can-you-stiffen-the-bb-area-on-a-frame ]here[/url] would a medium X0 rear mech cope with 44/29 & 11/32 cassette?
I'm hovering over the order button, so a quick reply would be great.
Thanks in advance.
Posted : 03/07/2009 7:10 pm
Probably
the long cage copes with just a double ring without dropping the chain (22 /36) though a medium is recommended for this application. You are just one tooth bigger so I would assume either med or long will be fine for your needs.
i have same cassette range as you
Clearly I have not tried this though but I think you will be OK.
Posted : 03/07/2009 8:47 pm
Many thanks JY, although I'm not quite sure of the first line of your post, I can see your saying it can take a 14 tooth difference, so assuming I don't try big/big or small/small I should be fine.
Cheers.
Posted : 03/07/2009 9:08 pm
I am saying that I (owna nd use the long cage mentioned above) should have a medium on my set up (as mine is really for a triple ring set up and a medium is recomended for mine with a front cog difference of 14 tooth.
Yours has only one more than mine so I think it will work with either a med or a long cage (which is the only one you can get that is NOT carbon cage)is that any clearer?
Posted : 04/07/2009 1:31 am
Er, I think so 😉
Cheers.
Posted : 04/07/2009 7:28 am
I only use medium cage SRAM mechs. I've got them set up on 22/32/44 with 11-32 and 11-34 cassettes on my bikes, they work perfectly and I can see no reason why they won't on your set up. TBH it baffles me why they bother with long cage mechs any more
Posted : 04/07/2009 8:05 am
Yes, it'll be fine.
Posted : 04/07/2009 11:31 am
