Will a roadrat take...
[Closed] Will a roadrat take a front mech?
[#2127634]
Does it have the cable stops etc.
Oh and how much of a faff is changing the rear wheel?
TIA
Posted : 26/10/2010 7:14 pm
Yes it will. Check the Cotic site for the diameter, I can't remember. It's a bottom pull, you'll need to glue a guide onto the BB. The downtube has cable stops.
Rear wheel change is a slight faff. It's a massive faff if you have mudguards though.
Posted : 26/10/2010 7:21 pm
my mudguards are fine on the rat, just set slightly back, wheel pops out easy enough 😆
Posted : 26/10/2010 8:49 pm
Yeah true dat. I had mine quite tight fitting and it was a right pain in the rear, part of the reason I sold it. Other than that, and the difficulty fitting a rack + rear disc brake (can easily be bodged though) it's a great bike.
Posted : 26/10/2010 9:01 pm
 cy
Cable guides don't need gluing, the frame is supplied with push fit guides to suit these days. It's a bottom pull 28.6mm. Changing the rear wheel without mudguards on isn't that tricky if you do it a few times in succession just to get things in the right order. Sure, it's not as simple as a vertical dropout, but it's way more versatile so the compromise is in assembly, not what you can do with it.
Posted : 27/10/2010 9:53 am
Never a problem here. Disc specific cheap rack from wiggle and BB7s work brilliantly!
Posted : 27/10/2010 9:56 am
