Wiggle Outlet
Wiggle Outlet
 PJay
[#13007527]
Some items on Wiggle are showing an "Outlet" badge (viewing the same items in CRC shows them to be clearance items).
Often there are additional discounts available if you spend a certain amount. Does anyone know if there are any for "Outlet" items?
Posted : 18/10/2023 12:38 pm
Not an answer to your question, but worth mentioning.... Apparently Wiggle/CRC trade under the following ebay seller for outlet items, many are used but there's some huge bargains to be had....
| eBay
Posted : 18/10/2023 2:13 pm
I was tracking a group set, it was 499 and has gone up by £10 since it got the 'outlet' tag
trisportresort can sometimes be a source of bargains, but often people get bidders frenzy and pay way over the odds. Have seen them shift returns for more than the price new!
Posted : 18/10/2023 2:24 pm
on wiggle front screen, and across the top bar, on a laptop screen, as opposed app viewing      SAVE £50 WHEN YOU SPEND £200! Use code SAVE
Ts&Cs apply
Posted : 18/10/2023 2:52 pm
lunge and lunge reacted
 PJay
The SAVE code only works with certain clothing products sadly.
Posted : 18/10/2023 2:55 pm
trusty, kelvin, trusty and 1 people reacted
chain reaction £10 off £150 spend, via british cycling, one code per month,
BC also now has 10% off tredz
Posted : 18/10/2023 2:57 pm
I was trying to buy a pair of wheels, but on separate auctions for each wheel... I bought the rear (with 12spd cassette and tyre) for under £80, didn't buy the front because it went for over £80!
Bought the same wheel brand new on CRC for ~£70..... ebay is a strange place...
Posted : 18/10/2023 3:39 pm
dc1988 and dc1988 reacted
 PJay
The OUTLET badges are showing on the main Wiggle site though.
Does it just mean that they're simultaneously on ebay?
Posted : 18/10/2023 3:44 pm
many are used but there’s some huge bargains to be had….
Theres used and theres USED, with many off them either coming off new display bikes, or without original packaging, or even a tiny mark. And most even listed as used have uncut steerers and clearly havent seen  a frame or wheel or brake fitting.
Last couple of wee bargains was a new 170mm 29er X-Fusion Trace 36 HLR which retail at £800 and it sold for £140 or the new 2023 Vitus Venon EVO-RS Rival eTap  which retails for £4k and went for £1600, or even my own a 2021 fox factory 36 listed as used but was pristine and clearly hadn't been fitted to anything. Got that for £310.
Posted : 18/10/2023 6:50 pm
