Wide bars on a 26er...
[Closed] Wide bars on a 26er?
[#5789521]
Maybe a stupid question but my new bars are 730, the current ones are 690. The new ones look massive but before I cut the new one should I try them at 730?
What's the real life effect apart from more leverage on a 26er?
Posted : 20/12/2013 10:45 pm
Try em. I like wide bars. 730 isn't massive btw.
Posted : 20/12/2013 10:46 pm
Ride em! Much easier to cut down later if you don't like them, rather than er, uncut up, if you were curious to see how wide bars feel!
Posted : 20/12/2013 10:47 pm
750 on two of mine, they're great.
Posted : 20/12/2013 10:53 pm
Yes it's kind of obvious that i should to that.
Just looked at the Kili flyer in Fresh Goods - that has 740's on and looks ok.
Posted : 20/12/2013 10:54 pm
You're hands will be further apart.....they might get lonely.Rub them together often to lessen the effect.
Posted : 20/12/2013 10:55 pm
Try it, but don't assume it'll be great. I ran 740s after riding 710s and 690s for years and loved it. The new bike has 785s and they're unpleasent- there is just too much bar.
Posted : 20/12/2013 11:00 pm
Also kinda depends what stem you are running the new wide bars with, no?
Posted : 20/12/2013 11:08 pm
The same one - 70mm 6 degree rise.
Posted : 20/12/2013 11:12 pm
It will feel a fair bit more stretched out with your weight further forwards. This may or may not be what you want / need.
Wider bars feels weird and horrible at first. But I suspect you'll get used it although it probably depends what kind of riding you do. Try it for 2-3 rides and then cut them down 10mm at a time.
Posted : 20/12/2013 11:21 pm
 myti
I've just gone up to 730's. I was worried about clipping my bars in the tight singletrack round here but not had a prob so far and really like the extra control it gives.
Posted : 20/12/2013 11:25 pm
You'll be amazed how 10mm difference feels, I went from 690 to 711 to 750, clipped a fair few trees along the way, but 750 feels spot on now, I might try an even shorter stem too.
Posted : 20/12/2013 11:37 pm
I'm happy with 750
Posted : 21/12/2013 12:08 am
