Wide bar with 12-15...
[Closed] Wide bar with 12-15 degree bend?
[#9301444]
I run OG bars with 25 degree bend on a couple of bikes (29+ and SS), but I'm after wider bars with less bend for my new DMR Trailstar build.
I've currently got some bars with a standardish 9 degree bend on it (15mm rise and 750 length), but would like something with more like 15 degree and similar rise and length.
Any suggestions, my Google-fu is obviously weak as I've not found too much out there.
Posted : 01/05/2017 11:00 am
Salsa Whammy bar?
Posted : 01/05/2017 11:02 am
Salsa bend 2?
Posted : 01/05/2017 11:04 am
Stooge moto bars are 800mm wide, 38mm rise, 17 degree sweep if you have about 20mm of spacers to drop your stem
Posted : 01/05/2017 11:07 am
Stooge motos were/are an option, but not in stock anywhere, and the rise is a bit big.
Salsa Whammy bars are only 10 degrees.
Salsa Bend 2 are not dissimilar to the OG bars in the 23 version. Can't see the 17 degree ones in stock anywhere - also they're £85!!!
Posted : 01/05/2017 11:20 am
Stooge motos aren't exactly budget either but reading their Facebook page suggests stock arriving in two weeks
Posted : 01/05/2017 11:48 am
I don't have any leeway with height, steerer us [i]just[/i] long enough. So I think the Moto bars would raise the front end too much.
Posted : 01/05/2017 11:54 am
On-One Fleegle...
717mm, 15 deg back sweep.
Love mine 🙂
[url= http://www.planetx.co.uk/i/q/HBOOFG/on-one-fleegle-handlebar ]On-One Fleegle[/url]
Cheers!
I.
Posted : 01/05/2017 1:16 pm
Fleegles would be spot on (and in fact I already own a set!) apart from they don't seem to have 31.8 versions.
My DMR Defy stem isn't suitable for a shim as it has two widely spaced clamps. I offered up some handlebar shims I have in the spares box - both are too narrow.
Posted : 01/05/2017 1:26 pm
Change stem into [url= http://slam69.co.uk/dartmoor-fury-v2-stem-254mm-318mm-35mm-9552-p.asp ]Dartmoor Fury[/url]. It is available in 25.4 and even in 35mm length...
Or [url= http://slam69.co.uk/2017-dartmoor-fury-v3-stem-21606-p.asp ]V3[/url] if you are after 45mm...
Alternatively try [url= http://allegro.pl/kierownica-amoeba-scud-720mm-31-8-os-272g-trial-i5224040293.html ]Amoeba Scud[/url]
It is 720mm and 15deg back sweep. 31.8mm clamping diameter.
You might struggle to get it in UK thou...
Cheers!
I.
Posted : 01/05/2017 1:46 pm
Syntace do their Vector bars in 8 & 12 degree backsweep, carbon or alu
Posted : 01/05/2017 4:00 pm
Thread revival time!
I couldn't find any of the above suggestions in stock - or at a reasonable price 😉
Anyway, I was perusing the Onza website, and they have these....
725mm wide, carbon wrap over Alu, 14 degree sweep, and currently reduced to £22. Just fitted them and they seem perfect, just the right amount of back sweep.
Posted : 31/05/2017 2:12 pm
SQ Lab also do nice 12 and 16 degree bars at decent widths
https://www.sq-lab.com/shop/en/handle-bars/
Posted : 31/05/2017 4:42 pm
Syntace?
I have some barely used 12 degree Syntace Vector carbons lying around, 740mm width and 12mm backsweep - if you want to buy them?
Posted : 31/05/2017 5:21 pm
I'd seen them, but still pretty pricy.
Tom - cheers for the offer, but I already bought the Onza ones. About to give em their first outing.
Posted : 31/05/2017 6:27 pm
